DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
2nd Gen Ram 1994 through 2001 Rams
Thread Tools Search this Thread
Old 07-14-2009, 02:44 PM
aim4squirrels's Avatar
aim4squirrels aim4squirrels is offline
2001 Dodge Ram 1500
Vehicle: 2001 Dodge Ram 1500 5.2L 2WD Reg Cab Long Bed
I say 180 simply to help keep the tranny cooler. That heat exchanger in the rad will heat the oil going back to the tranny if it was actually cooler going to it. I know it's on the cool side of the radiator, but the cooled 180* antifreeze should be cooler than the cooled 195* antifreeze all things being equal.
You're in the south and heat will kill that tranny quicker than anything.
As a slight off topic, I have an aux tranny cooler in my truck and I tried an experiment that has paid off big time.
The way the dodge boys rigged the aux cooler is that fluid would flow from the trans, to the aux cooler, then to the radiator "cooler." It's been 106* from 2 freaking weeks down here and my trans was topping out at 190*, which I wasn't happy about.
I switched the feed line from the trans to go into the radiator first and THEN to the aux cooler before running back to the trans. It now tops out at about 177* on my trans temp gauge. That's a 13* change just by swapping the two lines. It was super easy to do since I reused the quick disconnect when I deleted the check valve. Just food for thought.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 07-14-2009, 02:51 PM
Silver_Dodge's Avatar
Silver_Dodge Silver_Dodge is offline
Ram Moderator
Dodge Forum Moderator
1999 Dodge Ram 1500
My Garage
Yup, when I installed my aux trans cooler, I put it after the factory radiator.
__________________
1999 Ram 1500, 5.2, 4x4, Fastman 50mm, Modded kegger, HS 1.7's, Edelbrock headers, Magnaflow cat, Flowmaster Super 40, B&G PCM, 4.56' s, Auburn LSD, 3" Skyjacker, 3" PA body, 35" Toyo M/T's, lots of other goodies. www.cardomain.com/ride/799288
Old 07-14-2009, 03:55 PM
wjxavier's Avatar
wjxavier wjxavier is offline
1995 Dodge Ram 1500
Send a message via AIM to wjxavier
These are all things I still have to do yet. But alas, I have to get my bike running first so I have wheels to get back and forth to work.
Old 07-14-2009, 04:08 PM
nateblong nateblong is offline
Vehicle: 2000 Dodge Ram
Lots a great advice! Thanks guys. Yes aim4squirrels, I do have to run the octane booster to keep it from pinging. It only pings when set to performance with the Superchips 3815. I think that maybe the gas here in OK city sucks. In Florida I could get 93, here only 91 and I cant find any name brand places such as Mobil, Exxon, Sunoco....nothing! I dont belive that my has a leak. My truck only has 52,400 miles to date. So it does sound like using the 180 is a good idea for how I use the truck. I am going to grind that tab on the thermostat inlet so I can actually get it apart without taking of the compressor next time.
__________________
2000 Quad Cab Sport, 5.9L, 46re, from the cat mandrel bent duals, no mufflers, K&N fipk, 35/12.50/18 Toyo M/Ts, KMC wheels. Superchips 3815, Hell bent 2inch leveling spacers front, 2 inch Skyjacker add a leafs rear. 8.5mm MSD wires, Screamin Demon coil, brass distributor and rotor, Autolites. Always Mobil 1.
Old 07-14-2009, 04:15 PM
Laramie1997's Avatar
Laramie1997 Laramie1997 is offline
99% Insane
1997 Dodge Ram 1500
My Garage
Vehicle: 1997 Ram 5.2 4x4 RCLB
Send a message via AIM to Laramie1997 Send a message via Yahoo to Laramie1997 Send a message via Skype™ to Laramie1997
Quote:
Even with the tab there, you don't need to grind it down to remove. Check out my DIY.
http://dodgeforum.com/forum/2nd-gen-...t-install.html
__________________
See? Told Ya!
Old 07-14-2009, 04:18 PM
2001 Dodge Ram 1500
Man, that still shouldn't ping.
I'd park on a steeper hill or driveway and unbolt the TB and shine a flashlight into the back of the intake manifold. Look for some pooling oil. if it is pooling fix that plenum gasket. It won't only stop the ping, it'll pick up the performance a bit.
__________________
Old 07-14-2009, 11:46 PM
fukinavit fukinavit is offline
Vehicle: 99 ram 4x4, 5.9, auto, loaded.
unless your truck runs really hot, you drive lots in traffic or the ambient air temp is way high, i would not bother. you will not notice any performance difference, your fuel mpg WILL go down and in winter your heater will be cooler. i had a 180 but changed it back due to this. its up to you but i dont think its worth the bother.
Old 07-15-2009, 08:23 AM
Ram Moderator
1999 Dodge Ram 1500
My Garage
If you have a ping problem, it is worth the bother.
__________________
Old 07-15-2009, 06:57 PM
Well I guess its definitly going in then.
__________________
Old 07-15-2009, 07:30 PM
dodgeram2001 dodgeram2001 is offline
Vehicle: 2001 Dodge Ram 1500 4x4 5.9
Send a message via AIM to dodgeram2001 Send a message via Yahoo to dodgeram2001
Quote:
Originally Posted by Miami_Son View Post
If you do a lot of short hop driving then don't switch thermostats. You need your oil to get and stay hot enough to burn off water, acids and other combustion byproducts or sludge will form. This doesn't happen when you make lots of short trips with cooldown periods in between. It will be even worse with a lower temp t-stat.
what he said
__________________
Tags
07, 180, 2000, 80l, bad, colorado, dakota, degree, dodge, parts, ram, srt4, thermostat, thermostats, v10, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
