DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
2nd Gen Ram 1994 through 2001 Rams
Thread Tools Search this Thread
Old 07-29-2009, 05:02 PM
ladenblowfish ladenblowfish is offline
Vehicle: 1998 Dodge Ram 1500 4x4 5.9
Thumbs up Misfire
Hey guys. I haven't posted in a good while. I sold my 98 ram about two months ago but got the itch and gave the guy I sold it to a call and made an offer. So its mine again. Ha Ha! It was running good when I sold it to him but now it has a misfire on cylinder #4. He said it started after he changed the plugs and wires. I checked the plug and it looks new and gapped correctly. I replaced the wire to see if it was the problem but it didn't help. What else am I missing? Injector maybe? I did put some fuel cleaner in the tank but it didn't help.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 07-29-2009, 05:04 PM
Miami_Son Miami_Son is offline
2000 Dodge Ram 2500
My Garage
Vehicle: 2000 Dodge RAM 2500 V10 SLT+ Quad Cab 4X4
Hmmm...maybe you should vote for me for TOTM. That might clear it up.
Have you tried wiggling/disconnecting that injector to make sure that's not the problem?
Old 07-29-2009, 05:08 PM
VWandDodge's Avatar
VWandDodge VWandDodge is offline
Vehicle: 1997 Ram 1500 4x2
Sounds like the wires aren't properly routed.
__________________
<< Insert long list of crap that's been purchased and bolted on to said vehicle here >>
Old 07-29-2009, 05:44 PM
dhvaughan's Avatar
dhvaughan dhvaughan is offline
Vehicle: 01 1500 4wd
welcome back...
replace or swap that plug
swap injector #4 with another and see if the misfire moves.
compression check.
__________________
01 1500 Reg Cab 4wd 5.2 auto 3.55 285/75/16 nasta step bar tow hook sc3815 180 3923 trans cooler/filter posi-lok powertrax noslip timbren brite-box pioneer head rockford amp/speaker cobra cb firestick hughes plenum water pump timing chain oil pump rear seal front bearings brakes shocks cracked dash towing composting boat.
Old 07-29-2009, 07:34 PM
Well I changed the plug and wire. I'll swap the injector here in a bit to see if it helps. The guy checked the compression and it checked out fine. He did replace the flowmaster side exhaust I had installed w/ the used exhaust off a ram in a junkyard. He still had my exhaust so I'm putting it back on.
__________________
Old 07-29-2009, 07:40 PM
dhvaughan's Avatar
have you got a 304 code ?
__________________
Old 07-29-2009, 07:54 PM
jasonw's Avatar
jasonw jasonw is offline
2nd Gen Ram & PC Help
Dodge Forum Moderator
2001 Dodge Ram 1500
Vehicle: 2001 Dodge Ram 1500 4x4 QC
Send a message via Yahoo to jasonw
Route the plug wires properly.
TSB 18-48-98
What wires did you use? What plugs?
Also, did you replace the cap and rotor as well? If not, they are pretty cheap to do, and may solve the issue. Kind of a routine maintenance thing anyway. Get the brass kind, usually last longer.
But most importantly... go vote for Miami in TOTM, if you haven't already.
__________________
5.9L 360ci Magnum V8
Single 3" Flowmaster Super 44 Exhaust w/ Magnaflow Catalytic Converter
Volant Cold Air Intake Kit
Fastman 52mm Throttle Body
Modified Intake Manifold w/ Hughes Plenum Reinforcement Kit
SCT XCalibrator 2 Tuning by Hemifever
Awaiting Install: 3.92 gearing all around & Auburn LSD in rear axle
Solutions to Common 2nd Generation Dodge Ram Problems
Old 07-29-2009, 09:00 PM
I did get the 0304 code. I erased the code and it has come back on since I've replaced the other things. He replaced the cap, rotor, plugs and wires. He used Autolite wires. I grabbed a wire I had from another set for the truck and it didn't help. I swapped injectors and no light so far but still runs a little rough just not as bad. It would just idle a little rough but would run perfect once it starts moving down the road. I'm just gonna replace all the tune up items anyway and reroute the wires just to eliminate everything at once tomorrow. Just something simple. THe guy bought a Superchips tuner 3715 and what a huge difference it makes. With the 20" wheels before it was a dog, now its day and night different.
__________________
Old 07-29-2009, 10:01 PM
BlueBeast2's Avatar
BlueBeast2 BlueBeast2 is offline
2001 Dodge Ram 2500
Send a message via AIM to BlueBeast2 Send a message via Yahoo to BlueBeast2
Cracked head is my guesß
Old 07-29-2009, 10:06 PM
dhvaughan's Avatar
maybe not. he said PO checked the compression, so hopefully that's true.
__________________
Tags
dodge, missfire, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
