DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
Thread Tools Search this Thread
Old 07-31-2009, 09:20 PM
CSXfan's Avatar
CSXfan CSXfan is offline
1975 Dodge Ram 250
My Garage
Vehicle: 1999 Ram 1500 QC Sport 4x4 5.9
Default Front end issue, ball joints??
Hi all,
My '99 4x4 5.9l has been making some weird grinding/rubbing noises by the front drivers side wheel. So today I finally jacked the truck up and found that I could grab the top of the wheel and wiggle it back and forth about 1/4". Not good.
I know absolutely nothing about suspension, so I'm clueless as to where to go from here. Does this sound like bad ball joints? Or something worse? What do I need in order to fix this, and how difficult is it? Can I go another 1000 miles or so like this until I can get it fixed, or am I asking for trouble?
I've done quite a bit of engine work/reg maintenance on vehicles, but I've never had to deal with this kind of thing, so any help is appreciated. Thanks.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
If you're not livin' on the edge, you're taking up too much space.
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 07-31-2009, 09:40 PM
dsertdog56's Avatar
dsertdog56 dsertdog56 is offline
2000 Dodge Ram 1500
Vehicle: Mopar fan since 1968, owner since 1977, 2000 ram today.
Sounds like a bad hub bearing to me. You might want to plan on doing that ASAP, and your axle joints while its apart. Wouldn't hurt to check yuor ball joints either.
Chiltons/shop manual is an ideal place for the basics on this operation. Hardest part is getting the old stuff out.
__________________
MY NAME IS DOG, AND MY TANK IS EMPTY. GOT ANY SPARE CHANGE? Good vehicles are manufactured, great vehicles are built! Awesome vehicles are built by their owners using LUCK or Laboring Under Correct Knowledge. Ladenblowfish...you are a THIEF, and a COWARD!
Member #20 White truck club, and #29 in the 5.9 club!
Old 07-31-2009, 09:45 PM
Me&MyMopar Me&MyMopar is offline
Vehicle: 2000 dakota QC 5.9
Sounds to me like bad wheel bearings. I would get it up in the air and try moving it from behind to see where the play in the wheel is coming from, but my money is on the bearings.
Old 07-31-2009, 09:48 PM
Aubrey's Avatar
Aubrey Aubrey is offline
Vehicle: 95 Ram 1500
It could be the bearing but, grabbing the top and moving it could very well be the ball joints. You need someone to watch your balls while you wiggle your meat.
__________________
95 1500 5.9, 3" SJ Sys & Diesel Coils, 35" Trxus M/T, 16" Streetlocks, 4.56, Auburn Posi, Ox Lock, Hella, Remote start, K&N, Flowmaster50, 4x4 Posi-Lok, Custom front/rear bumpers, 9500 winch, 1-ton Steering
Old 07-31-2009, 09:54 PM
Miami_Son's Avatar
Miami_Son Miami_Son is offline
2nd Gen RAM Moderator
Dodge Forum Moderator
2000 Dodge Ram 2500
My Garage
Vehicle: 2000 Dodge RAM 2500 V10 SLT+ Quad Cab 4X4
Yeah, but ball joints don't usually make grinding noises. My bet is on the bearing.
__________________
2000 Dodge RAM 2500 Sport SLT+ Quad Cab 4X4, 8.0 V10, 4.10 gears, Borla SS Headers, Edelbrock muffler, K&N CAI, KYB Shocks, Hell Bent 2" Level Kit, 17" American Racing Wheels (Baja), factory camper/towing pkgs, WAAG Sidesteps, member White Truck Club #87
Old 07-31-2009, 09:59 PM
dhvaughan's Avatar
dhvaughan dhvaughan is offline
Vehicle: 01 1500 4wd
bearing. you might can continue to drive it for a little while longer if you pay close attention to it and monitor its condition. if the play increases or the noise worsens then STOP.
i replaced mine back in the winter. i was expecting the worst, but it wasn't too bad. here's a nice how to. you remove the wheels, brakes, caliper supports, unbolt the big axle nut and then the 3 bolts on the back. if the big nut comes off and the bearing comes out, then its easy. if either of those are froze/rusted in, then it becomes a bitch. mine came right off and i was glad it did.
http://www.pavementsucks.com/tech/hub.php
edit ^ the diy is for hub bearings and u-joints. so leave the axles in, tap the bearings out and replace them.
__________________
01 1500 Reg Cab 4wd 5.2 auto 3.55 285/75/16 nasta step bar tow hook sc3815 180 3923 trans cooler/filter posi-lok powertrax noslip timbren brite-box pioneer head rockford amp/speaker cobra cb firestick hughes plenum water pump timing chain oil pump rear seal front bearings brakes shocks cracked dash towing composting boat.
Old 07-31-2009, 10:09 PM
Miami_Son's Avatar
2000 Dodge Ram 2500
My Garage
That's a good DIY, but it isn't necessary to remove the axle shafts to replace a hub. Better to leave them in rather than risk damaging the seals.
__________________
Old 07-31-2009, 10:25 PM
Aubrey's Avatar
Ah, missed that, yeah, bearing.
I have one that needs to be replaced too. I'm not thrilled about replacing another one.
__________________
Old 07-31-2009, 10:31 PM
dhvaughan's Avatar
Quote:
correct. leave axles in and just tap the bearings/hubs out.
__________________
Old 07-31-2009, 10:38 PM
CSXfan's Avatar
1975 Dodge Ram 250
My Garage
Wow thanks for the DIY, good stuff there.
I think the grinding noise is the break pads rubbing funny because of the angle of the rotor, but I could be wrong. It goes away when I apply the breaks. It doesn't grind all the time, usually after making a right hand turn. It also makes a popping noise during slow speed turns when I turn the steering wheel. The popping doesn't increase/decrease with wheel speed. (this isn't because of a loose track bar like I thought in my earlier thread)
How much can I expect to pay a shop to do the replacement for me? I need this done as quick as possible. I broke my motorcycle last night, still haven't replaced our mazda after the bday bash flood, and our other truck is hauling the camper all next week. Kind of a crappy time to break things on the ram...
__________________
Tags
1500, 2000, 2500, 4wd, ball, balls, diy, dodge, end, front, joint, joints, magnum, ram, remove
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
