DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
Thread Tools Search this Thread
Old 08-16-2009, 11:30 AM
cmckenna cmckenna is online now
Vehicle: 96 Dodge RAM 1500 4WD
Default Noisy Oil Pump
I just got done replacing my intake, water pump, timing chain and oil pump on my 96 RAM and there's a very loud sound coming from the oil pan. Now, what I failed to do was to check the placement of the pickup tube. Could the crank be hitting it? It is very loud. In fact, I am not sure what is causing the noise. I rolled under it and it's definitely coming from the oil pan. Any advice on this noise issue? Prior to this, the old one was dead quiet. No noise until after the change was made.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-16-2009, 12:16 PM
dhvaughan's Avatar
dhvaughan dhvaughan is offline
Vehicle: 01 1500 4wd
ok, what does it sound like ?
tick tick tick
roar roar roar
growl growl
clack clack
and do you have oil pressure or not.
you need to take it back apart and see whats wrong. it shoudn't make any noise at all.
when i changed mine, i failed to overlap the flex plate cover ip with the oil pan exactly right. it went clack clack clack as a flex plate bolt hit the cover. i had to take the starter and flex plate back off
__________________
01 1500 Reg Cab 4wd 5.2 auto 3.55 285/75/16 nasta step bar tow hook sc3815 180 3923 trans cooler/filter posi-lok powertrax noslip timbren brite-box pioneer head rockford amp/speaker cobra cb firestick hughes plenum water pump timing chain oil pump rear seal front bearings brakes shocks cracked dash towing composting boat.
Old 08-16-2009, 01:05 PM
Ok, the oil pressure is fine. New oil sending unit as well. The sound is very hollow sounding.
I was just going to remove the flex plate actually. It's hard to describe the sound.
It's not a ticking sound nor a clacking sound. It is not high pitched. It is mid range in pitch and sounds very hollow. Whirring or roaring maybe.
I was just taking the flex plate off actually. So, I will start there first.
Old 08-16-2009, 03:12 PM
Removed the plate, doesn't seem to be any interference. Going to pull the pan.
Old 08-16-2009, 04:02 PM
Problem solved. Upon closer inspection of the flex plate, there was evidence of interference. I removed it and ran it. No more noise. Thank you very much for your advice as it helped. I was not in the mood to remove the oil pan today. Thanks again.
Chris
Tags
1500, 2000, dodge, intrepid, loud, makes, noise, oil, pan, pump, ram, replacing, sending, unit, vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
