Hey everyone. I'm going to fabricate a custom rear bumper with steel pipe. I'd like some pics or ideas if anyone would like to chime in, including the material I should use ( diameter, thickness, etc..) Nothing stainless steel, just basic. I'm going to rhyno line it to match the front bumper when its done.
Thanks!
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
__________________
Keegan
Sponsored Links
Registered users do not see this ad. Click here to register for free!
8" steel pipe with a wall thickness of 1/8" probably wouldn't look too bad. one idea is to put caps on both ends then put a valve stem and a air hose hookup so you will always have spare air in the bumper.
__________________
I'm sorry, I can't hear you over the sound of how awesome I am.
Keegan, when you say "steel pipe", are you referring to tubing? If so, .040-.050 thickness will be more than adequate. If you plan on making and bends in the tube, .050 you will need a power bender. Midwest 4x4 used to offer weld together kits that had all the tubing precut and notched, just weld it up.
__________________
01 1500 XCab 2WD,5.2. Edelbrock/AEM Dryflow 14x3 RAC. Summit Performance Cap,Rotor,and 8.5mm wires hooked to Autolite plugs.MSD 8228 Coil. Superchips 3815. Royal Purple for the fluids. Hughes Engines Underdrive Pulleys, Hypertech 180 T-Stat. Bronze Truck Club #1
