DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
Thread Tools Search this Thread
Old 08-24-2009, 01:47 PM
pdeltoid pdeltoid is offline
Default A/C compressor clutch noise
Hi,
1998 Ram 1500, 5.9L.
Just ran into a new problem yesterday. A/C Compressor is making a howling/grinding noise when it unlocks and disengages. A/C works fine, blows nice cool air in low and max A/C. I can clearly tell the noise is from the compressor clutch.
I have never re-charged the freon in the truck, owned it since new. I don't know if there are any leaks in the system, as I said, it seems to blow cold air just fine.
When I unplug the electrical connector to the compressor, I get the howling noise as the clutch disengages.
When the clutch is engaged and turning, no noises. When it disengages, noise again. When the engine is off, and I turn the inside portion of the compressor clutch, i hear and feel grinding. Bad news I am sure.
I recently changed out the water pump and timing chain, so I know there is no problems there. Its not the PS pump either.
Any ideas here on fixing this? I'd rather not get into discharging the system, and I really don't need A/C right now, but I'd rather not cause any damage bypassing it. I like doing repairs on my own, but am wary of the A/C system.
Thanks for the advice!
Mark
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-24-2009, 03:24 PM
Ram15002ndGen's Avatar
Ram15002ndGen Ram15002ndGen is offline
The bearings or the clutch plate on the compressor is going out. If you can move it manually and hear the noise, I would say it's pretty far gone. You can try to lube it with some WD-40 and see if that helps with the noise, but I think it's just a matter of time. Some people try to change out the clutch and see if that makes it better, but if not then that means it's the compressor. I would say wait till it goes out and get both new compressor and clutch. Yes, sometimes you can buy them separate, but to me it makes no sense mating a new part to an old part. I would replace both for optimal performance.
__________________
1997 1500, 318 CID, 4x2 Laramie SLT, Extended cab, Pendaliner SR bed liner, After market fogs in OE slots, Bone stock, Dodge Mud Guards, Custom tool box under hood on pass fender, Laramie Club Member, Black Truck Club Member 111.
Old 08-25-2009, 01:24 AM
To bypass the A/C system, do I simply disconnect the electrical connectors and run a shorter belt?
Thanks.
Old 08-25-2009, 01:36 AM
Yea, if you put on a shorter belt you should be OK. If it's not turning it wont make any noise. Look on your radiator mount and it tells you the alternate method of routing your belt without the A/C.
__________________
Old 08-25-2009, 04:36 PM
Thanks for your help, I'll give that a shot!
- Mark
Tags
ac, air, bearing, clutch, comp, compressor, conditioner, dakota, dodge, engages, grinding, noise, noises, ram, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
