DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
Thread Tools Search this Thread
Old 08-26-2009, 03:22 PM
cmckenna cmckenna is offline
Vehicle: 96 Dodge RAM 1500 4WD
Quote:
Originally Posted by Laramie1997 View Post
I don't think you have rust in the fuel rail. From the pics, it looks like you have the plastic fuel rail. IIRC, plastic wont rust.....
Those look like welded mounts to me- not plastic. You can even see the rusty inlet fitting.
Always replace with new ones or, you can have someone make you a set of Al ones for less than what it costs to buy new OEM. I would avoid junkyard fuel rails as well. Reason being is that they have been sitting without gas in them for God knows how long and, the insides are probably corroded worse than yours.
Get new ones.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-26-2009, 03:31 PM
Quote:
Originally Posted by Dr Donut View Post
I believe iac is on tb and all of those sensors were replaced and i soaked all the parts in a bucket of gas one night and in a parts cleaning tank the night before that didn't really see any rust in the fuel lines but I didn't look until after they soaked and I flushed them so I'll take them back apart, if that is the problem should I replace the rails and is there a good place to buy them?
Yeah, buy new. If all the sensors are new and the TB is free from carbon- it's your fuel system. I would junk / trash those old ones and get new ones.
You can get a new set here:https://www.dodgetruckparts.net/dodge-parts-search.html
The only other option is to have custom rails made. If your interested in this route just let me know. CM
Old 08-26-2009, 04:46 PM
Dr Donut Dr Donut is offline
2001 Dodge Ram 1500
Vehicle: 01 ram 1500 4x4
well after seeing how much new rails cost I would be interested in going the custom route. CM if you know someone who does this or you do feel free to pm me
__________________
Small tires are like small tits
Old 08-26-2009, 05:36 PM
Sent a PM
Old 08-26-2009, 06:25 PM
RamMan4x4 RamMan4x4 is offline
Vehicle: '99 Dodge Ram 1500 4x4 Sport
have you checked for a vacuum leak?...a bad enough leak can cause rough idle and possibly a stall. Use an unlite propane canister (like the one used on camping grills) and hold it next to all the vac lines (esp the one to the brake booster), if you hear a surge in throttle while doing this, you found your leak.
EDIT: vac leak wouldn't go away after 5min of driving...that's what I get for speed reading.
__________________
99 Dodge Ram 1500 4x4 - 100k, 360ci-V8, Hughes Plenum Kit, 180 degF T-Stat, 1-Chamber Flow Master, Tow Hooks, 33" BFG-AT, Optima Red Top
03 VW Jetta TDI - Silver, 120k, 5spd, Vag-com, DG Racepipe, Ventectomy, ON CCV, 4pt lift pads, 17" Audi TT wheels, E-Codes, Stubby Antenna
Old 08-26-2009, 08:55 PM
Ram15002ndGen's Avatar
Ram15002ndGen Ram15002ndGen is offline
I have the plastic fuel rails on mine and I'm sure you do too Laramie, but I have often wondered if they are plastic all the way through or just plastic coated aluminum? I have trouble believing that the plastic would hold up to 13 years of pressurized gas going through them and the heat of the engine bay without them giving out. Mine don't have the pressure connector unfortunately. Can't test fuel pressure if I ever need to.
__________________
1997 1500, 318 CID, 4x2 Laramie SLT, Extended cab, Pendaliner SR bed liner, After market fogs in OE slots, Bone stock, Dodge Mud Guards, Custom tool box under hood on pass fender, Laramie Club Member, Black Truck Club Member 111.
Old 08-27-2009, 02:51 PM
2001 Dodge Ram 1500
Just a thought I had could an 02 sensor cause this problem when I got the duals put on I drove it about 45 min the no pipes and the sensors wire tied behind the manifolds so they didn't scrape, it did this before but it seems to be much worse now, it's also been a little colder so I don't know if this would affect it at all.
__________________
Old 08-27-2009, 02:58 PM
Laramie1997's Avatar
Laramie1997 Laramie1997 is online now
The Moderator From Hell
Dodge Forum Moderator
1985 Chevrolet Monte Carlo
My Garage
Vehicle: http://www.cardomain.com/ride/3337823
Send a message via AIM to Laramie1997 Send a message via Yahoo to Laramie1997 Send a message via Skype™ to Laramie1997
Quote:
Mine was a little too flimsy when I took it off for the plenum job to be plastic covered aluminum....
__________________
Mein Kampf- Yes, I have one of my own
Is now creating sigs Look
Red Truck Club Number 7
To vote in polls
1. Member for 30 days
2. 50 or more posts!
Old 08-27-2009, 04:21 PM
Neither Aluminum or Copper is certified / approved for pipe style fuel rails or fuel feed-lines. It will work harden and develop stress cracks over time. Solid billet Al and extrusions are acceptable however for fuel rails and fuel blocks only. Not intended for fuel injection fuel delivery lines.
What is the material that composite fuel rails are made out of? It has to be both fuel and heat resistant as well as meeting burst tests and burn tests, UV tests, temp cycling tests, mechanical shock and vibration tests, salt tests and more.
If someone knows what these "plastic" fuel rails are made out of please post it here. I am very curious to read what the material is as I have never seen plastic fuel rails before nor heard of plastic fuel rails. Just curious that's all.
The coating on the metal fuel rails is a powder coated type of coating. It is not very thick either. The MIL thickness on that looks very thin on mine. It has to be thin so that the I.D. and O.D. are not grossly affected by paint thickness and go out of tolerance.
Old 08-27-2009, 08:52 PM
frankie27 frankie27 is offline
1998 Dodge Ram 1500
Vehicle: 98 ram 1500 5.9 liter laramie SLT QD cab 4X4
are you throwing any codes. if its the up stream 02sensor unhook negative, unplug upstream sensor, turn key over for 20 seconds, hook negative back up, drive 60 mph, then see if it still does it, and if it does its not the 02sensor.
Tags
1500, 96, dodge, driving, durango, idle, idles, idling, issues, problems, ram, rough, smooths, start, suv
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
