DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
Thread Tools Search this Thread
Old 09-08-2009, 06:17 PM
turtlehead turtlehead is offline
Vehicle: Dodge Ram
Default Need Help With AC switching to Heat
I own a 2000 Ram 1500 Sport Package 5.9 L, I have two issues:
1. While driving with the AC on, i hear a pop and heat comes out. Sometimes it does it randomly, but mainly does this while I'm applying the brakes or slowing down. To get cold air, I have to turn the AC off and back on, which doesn't always work.
I tried researching the issue, but found nothing. Maybe relay switch, tensioner, or serpentine belt.
2. While accelerating 15 - 25% of throttle, i hear a loud scratching noise coming from engine. I did replace serpentine belt, but no resolve. Could it be the fan or tensioner, maybe its the cause of my AC problem.
Please let me know if you have any idea, thanks.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 09-08-2009, 06:56 PM
Miami_Son's Avatar
Miami_Son Miami_Son is online now
2nd Gen RAM Moderator
Dodge Forum Moderator
2000 Dodge Ram 2500
My Garage
Vehicle: 2000 Dodge RAM 2500 V10 SLT+ Quad Cab 4X4
If you mean that the A/C stops blowing through the panel vents and instead blows through the heater/defroster ducts, then do a search on wild or crazy vents. This is a common problem that has been discussed many times before in here.
__________________
2000 Dodge RAM 2500 Sport SLT+ Quad Cab 4X4, 8.0 V10, 4.10 gears, Borla SS Headers, Edelbrock muffler, K&N CAI, KYB Shocks, Hell Bent 2" Level Kit, 17" American Racing Wheels (Baja), factory camper/towing pkgs, WAAG Sidesteps, member White Truck Club #87
Old 09-08-2009, 07:00 PM
Ram15002ndGen's Avatar
Ram15002ndGen Ram15002ndGen is offline
The A/C issue is common for your year vehicle. Do a search for "Wild Vents" and that will give you a lot to go on. It's a problem with the vents and vacuum under your dash. That noise may also be related to it.
__________________
1997 1500, 318 CID, 4x2 Laramie SLT, Extended cab, Pendaliner SR bed liner, After market fogs in OE slots, Bone stock, Dodge Mud Guards, Custom tool box under hood on pass fender, Laramie Club Member, Black Truck Club Member 111.
Old 09-09-2009, 04:57 AM
Vehicle: Dodge Ram
Thanks for the responses. My issue isn't heat coming from dash / defroster, it just blasts heat from the ac vents (upon decelaration). But I'll try some of the diagnostics for treating wild vents, maybe that'll help me find a solution.
I'll post my resolution, if I find one, thanks again brothers
Old 09-09-2009, 06:04 PM
uli2000 uli2000 is offline
Please LMK if you find anything further. I just got a 2001 5.9l sport today and am having the exact same problem.
Old 09-09-2009, 06:08 PM
Vehicle: Dodge Ram
Default A little more info
Well I just figured out now by just switching the ac fan from low to high rapidly, it jumps to heat. I then have to turn it off and put he fan on low and back on for it to work agan.
Old 09-10-2009, 07:17 AM
speeddemon31176's Avatar
speeddemon31176 speeddemon31176 is offline
1988 Ford Thunderbird
My Garage
Vehicle: 97 RAM 1500 club cab 4x4
That is your panel for your heat/ac moving back and forth. You are having a wild vent issue but it is the "flapper" under the dash that is doing it. Review the wild vent thread and it will lead you to the fix for your problem.
__________________
1997 1500 4x4 club cab, Flowmaster true duals 2.25" with high flow cats, 4" Skyjacker susp./3" body, Cowl Induction hood-non-op.
Old 09-11-2009, 08:13 AM
Vehicle: Dodge Ram
Default Problem Solved!
Found the problem. The "flapper" is called a Blend Door. I'm not a technical nerd so I don't know what most parts actual names are.. But under the glove box, there's the heater core (I guess) and attached to it is a small black box, square shape, held on by two screws. It's a motor which turns a small black piece which switches ac to heat. That little black piece is a bad design and will crack, like mine did. Since I live in AZ, I just made sure it was rotated to ac and took off the black box and left it off so that it can't switch to heat. At leas until I order the part.
You probably won't understand my directions, so here's the website which fully explains everything and has pictures and a replacent part.
http://www.heatertreater.net/Dodge%20Ram%2095-02.htm
Old 09-11-2009, 02:33 PM
My Garage
Yep that's what I was talking about the blend door. I couldn't thing of the name for it for the life of me. glad to see you found the problem and the solution.
__________________
Old 09-21-2009, 10:18 AM
Vehicle: Dodge Ram
Default Thanks
Ya I'm glad it's fixed. Thanks for all the help, couldn't have done it without you.
Tags
a/c, heat, heater, problem, scratch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
