DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
Thread Tools Search this Thread
Old 09-09-2009, 01:22 PM
Aubrey's Avatar
Aubrey Aubrey is offline
Vehicle: 95 Ram 1500
Default 1-Ton Steering Upgrade
I got my 1-ton steering linkage on this weekend. It's an easy install and it replaces the inverted Y linkage on the 1/2 tons. I posted pics of everything and some that shows the size differences in the bars in my album in my profile here.
I believe the 1-ton linkage started to come in around 98 on the 3/4 tons. With this change you do loose the steering stabilizer but, you can get a mounting bracket aftermarket to put it back on if you want. You'll need a 7/8 and 13/16 socket to remove the old and just the 13/16 socket to install the new. Torque them to 60 ft lbs and grease them and then get an alignment. There is a difference in the taper on the ball joints. The 1/2 tons are a .7-.86 taper and the 1 ton is .7-.88 taper. The bars are thicker as you can see in the pictures. I put the wrench on the new first and then you can see how much wider it is on the old.
I used the NCP line from Napa. I priced out the 1/2 and 1 ton parts and the 1/2 ton is only $6 cheaper. After looking at the ball joints taken apart, I decided I did not want to go with the Moog parts. I do not know what those would be priced at though. Here are the parts and their online prices.
269-3148 Tie Rod End at pitman $64.99
269-1123 Adjusting sleeve at pitman $28.99
269-6096 Tie Rod End draglink $69.99
269-6095 Tie Rod End passenger knuckle $219.00
269-1201 Adjusting sleeve on driver side $54.49
269-3208 Tie Rod End left outer driver knuckle $67.49
It does feel tighter but my old stuff was pretty worn so I don't know if the new design makes that much of a difference. There were no issues during the alignment. I have not had it offroad yet so I don't know how it does there with any kind of kickback. enjoy
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
95 1500 5.9, 3" SJ Sys & Diesel Coils, 35" Trxus M/T, 16" Streetlocks, 4.56, Auburn Posi, Ox Lock, Hella, Remote start, K&N, Flowmaster50, 4x4 Posi-Lok, Custom front/rear bumpers, 9500 winch, 1-ton Steering
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 09-09-2009, 02:33 PM
Ramman18 Ramman18 is offline
Nice. Pretty spendy though. I'll stick with my stockers for now.
__________________
1999 1500 4x4 Xcab SB 318 nv3500 hypertech PPIII
180 stat Champion Truckplugs 4071
Flowmaster 50 Magnaflow Cat
Nitto Terra Grappler 285/75 R16 Thuren track bar
Old 09-09-2009, 04:11 PM
dsertdog56's Avatar
dsertdog56 dsertdog56 is online now
2000 Dodge Ram 1500
Vehicle: Mopar fan since 1968, owner since 1977, 2000 ram today.
Looks like ya beat me to the install sir...the parts aren't any more expensive then replacing the weak 1500 TREs and bolt right in the newer 2000/up 1500s. No taper adjustments required.
__________________
MY NAME IS DOG, AND MY TANK IS EMPTY. GOT ANY SPARE CHANGE? Good vehicles are manufactured, great vehicles are built! Awesome vehicles are built by their owners using LUCK or Laboring Under Correct Knowledge. Ladenblowfish...you are a THIEF, and a COWARD!
Member #20 White truck club, and #29 in the 5.9 club!
Old 09-09-2009, 04:24 PM
PurplDodge's Avatar
PurplDodge PurplDodge is offline
1999 Chevrolet S-10
My Garage
Vehicle: Dont drive....
I will have to do this. My steering needs to be replaced anyway, so why not upgrade?
__________________
My name is Nathan and my tank is full
Oil Change DIY Plenum Gasket Repair FAQ
Old 09-09-2009, 07:09 PM
dhvaughan's Avatar
dhvaughan dhvaughan is offline
Vehicle: 01 1500 4wd
what's the advantage ? just size and strength of the parts ?
what about the steering box, can you replace it with a heavier one, and would you want to ?
__________________
01 1500 Reg Cab 4wd 5.2 auto 3.55 285/75/16 nasta step bar tow hook sc3815 180 3923 trans cooler/filter posi-lok powertrax noslip timbren brite-box pioneer head rockford amp/speaker cobra cb firestick hughes plenum water pump timing chain oil pump rear seal front bearings brakes shocks cracked dash towing composting boat.
Old 09-09-2009, 08:04 PM
Aubrey's Avatar
The parts are larger but some would say the design is better. You have a tie rod that goes knuckle to knuckle and a drag link from pitman to the far end of the tie rod. The stock setup goes from pitman to knuckle and from drag link to knuckle.
I am pretty sure the boxes are interchangable but the only difference is that the 1/2 ton is a variable and the others are non variable. I am pretty positive that is the only difference.
__________________
Old 09-09-2009, 09:56 PM
olyelr's Avatar
olyelr olyelr is offline
Vehicle: 2000 Dodge 1500 5.9, reg. cab short box, auto
Quote:
You are absolutely correct.
Sweet deal on the upgraded steering. I have been giving this some thought as my steering is all the stock OEM parts (after 160k miles, just wont give up!). I will have to check your pics out. Sounds like a simple bolt on swap.
__________________
<img src=http://dodgeforum.com/forum/image.php?type=sigpic&userid=99095&dateline=1228715641 border=0 alt= />
2000 Dodge Ram 1500, 1 ton coils/Add-a-leafs, 3" body lift, 35x12.5x17 BFG Mud's
Old 09-09-2009, 10:05 PM
dodge15004x45.9 dodge15004x45.9 is offline
2001 Dodge Ram 1500
Vehicle: Ram 1500 4x4 5.9 auto reg cab 8ft bed Cherry bomb muffler k&n intake.
Send a message via AIM to dodge15004x45.9 Send a message via Yahoo to dodge15004x45.9 Send a message via Skype™ to dodge15004x45.9
This is kind ot. What is that pice called that goes across the from diff? The lowest bat the steering dampher conects to it? Mine is bent and I need a new one. Any good ones out there?
__________________
01 ram 1500, 4x4, 5.9, 3" top guns customz lift. PA truck club join here>http://dodgeforum.com/forum/dodgefor...ruck-club.html
Old 09-10-2009, 12:06 PM
Aubrey's Avatar
My stock pieces had 184,000 miles on them. The ball joint seals had some splits so I just wanted to replace them all. Figured it was time.
The track bar. They are bent normally. Not sure if you mean it is bent beyond the stock bend. If you want just that piece, you'll probably only be able to get a stock replacement. The only difference is who makes it and how they build their ball joints.
__________________
Old 09-10-2009, 04:01 PM
helms helms is offline
1987 Chevrolet Camaro
My Garage
Vehicle: 2002 2500 SLT laramie 5.9
lol, my truck has the same setup as your stock stuff. i will definatly be doing this mod. good info to have.
__________________
2002 2500, 5.9 V8, 4x4, MSD, Flowmaster super 40 cat delete, Airaid, Autometer, BDS, Rancho, 35" Toyos
Tags
1500, 2007, 2500, 269, 2693148, 3208, 95, dodge, linkage, napa, part, ram, steering, ton, upgrade, upgrades
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
