DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
Thread Tools Search this Thread
  #31
Old 09-20-2009, 05:11 PM
Laramie1997's Avatar
Laramie1997 Laramie1997 is offline
The Moderator From Hell
Dodge Forum Moderator
1985 Chevrolet Monte Carlo
My Garage
Vehicle: http://www.cardomain.com/ride/3337823
Send a message via AIM to Laramie1997 Send a message via Yahoo to Laramie1997 Send a message via Skype™ to Laramie1997
Dodger, I would bet that you have managed to pop the amps. See if you can isolate the speaker wires colors coming from the back of the harness to those amps and see if you can go around them. Ideally, I would tell you to just run all new wire, but if you can chop into it and make it work, then that will tell you what the problem is/was.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
Mein Kampf- Yes, I have one of my own
Is now creating sigs Look
Red Truck Club Number 7
To vote in polls
1. Member for 30 days
2. 50 or more posts!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
  #32
Old 09-20-2009, 05:13 PM
dodgerdriver dodgerdriver is offline
Since I already changed the H/U and it didn't make a difference, I guess checking the speakers in the front door is next. I read in other threads that there is an amp at each speaker. Is that true?
  #33
Old 09-20-2009, 05:40 PM
Miami_Son's Avatar
Miami_Son Miami_Son is offline
2nd Gen RAM Moderator
2000 Dodge Ram 2500
My Garage
Vehicle: 2000 Dodge RAM 2500 V10 SLT+ Quad Cab 4X4
Only on vehicles equipped with the optional Infinity Premium Sound System, an indicator of which is the pillar tweeters.
__________________
2000 Dodge RAM 2500 Sport SLT+ Quad Cab 4X4, 8.0 V10, 4.10 gears, Borla SS Headers, Edelbrock muffler, K&N CAI, KYB Shocks, Hell Bent 2" Level Kit, 17" American Racing Wheels (Baja), factory camper/towing pkgs, WAAG Sidesteps, member White Truck Club #87
  #34
Old 09-20-2009, 06:45 PM
Thanks much. I appreciate the help. Have a good day/night.
  #35
Old 09-20-2009, 08:22 PM
Augiedoggy's Avatar
Augiedoggy Augiedoggy is offline
1996 Dodge Ram 1500
Vehicle: 96 ram ext cab 4x4 that followed me home and drained my bank account
Miami son how exactly are you disagreeing with me?.... I was always under the impression a car stereo was designed for the industry standard 4 ohm car speaker .thats what the power output is rated as is a 4 ohm load... running a lower ohm load on a amplifier whether it be an external or HU amp will increase the heat (and power to each speaker) generated by the amp... this is a pretty commonly known thing..... when I dropped my ohm load to a half an ohm by wiring my 2 dual voice coil speakers in parallel and then again in parallel and bridged my amp to one channel that put a 1/2 ohm load on the amp and it runs soo hot now I needed to add cooling fans to assist in keeping it from overheating...(the audio art amp is only 1 ohm stable bridged.)
Thats one of the things that effect price on an amp....the ability to be stable at lower ohm loads. my orion hcca is a two channel amp thats only 25 watts rms but when I bridge it and run it in a 1/2 ohm load configuration its actually outputting close to 400 watts rms to each of the 4 voice coils..this allows one to compete in a lower power class while actually having a greater power output. Most run of the mill amps are only two ohm stable and when you brige them they are 4 ohm stable....cheaper amps are less efficient and the power increase is less when cutting the ohm load.
"Using a 2 ohm speaker on a system designed for 4 ohms will result in a slight increase in decibel level at a given volume setting, but you run the risk of speaker damage from overdriving it"
this is the same thing I was saying except on higher quality amps cutting the ohms load in half actually doubles the power output of the amp in theory.... when I said the sound quality isnt as good in this configuration thats because thats what I read in one of my car stereo installation books....just checked it again. I cant speak from personal experience on that as I've never noticed it myself.
  #36
Old 09-20-2009, 08:50 PM
Miami_Son's Avatar
2000 Dodge Ram 2500
My Garage
I'm disagreeing with you on semantics more than anything else. Resistance creates heat, so higher resistance means more heat and amp overload. Most home audio systems are designed for 8 ohm speaker loads. Car stereo is more towards 4 ohms except in the case of subwoofers, which are either 2 or 4 ohms. A 4 ohm system can usually handle a 2 ohm speaker just fine, but the problem comes in when that 2 ohm speaker is designed primarily for low frequencies and the user then boosts the output level to compensate for the amplifier's inability to provide a decibel level to their liking. Now, the amplifier is being asked to do more than it can handle, but it isn't overheating solely because of the use of 2 ohm speakers. Like I said, the important thing is to match your speakers to your system. Any claims as far as power handling and frequency response are based on this. Mixing components is always a recipe for failure of something, regardless what the specific reason might be. Heat, whatever the cause, can destroy an amp, but even moderate heat that doesn't damage an amp can cause a reduction in efficiency and sound quality.
__________________
  #37
Old 09-20-2009, 09:03 PM
Augiedoggy's Avatar
1996 Dodge Ram 1500
thats why some amps rate different distortion levels at different ohm loads...(THD%)'and subwoofers come in 2,4 and 8 ohm load configurations because many are designed to be used in different wiring schemes to manipulate the ohm load to the amp....
for example 8 ohm subwoofers are usually installed as 2 woofers wired in a parallel to put a 4 ohm load on the amp and 2 ohm woofers are designed to be wired in a series to put a 4 ohm load on the amp....and usually dual voice coil woofers are sold in 8 or 2 ohm coil setups I actually made a mistake above and said mine were wired in a series...
this site explains it better than I can for anyone reading this who wants to understand better...
http://www.termpro.com/articles/spkrz.html
Tags
1500, 1997, 1999, 2000, 6x9, amp, chrysler, dodge, front, load, location, ohm, premium, ram, sound, speaker, speakers
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
