Official 2nd Gen Ram of the Week Poll-Lifted Trucks
We have an awesome lineup of RAMs this week.
1. Silver_Dodge MOD List
Here's the list of all the stuff I can think of that I have done to the truck:
Mopar Performance air filter assembly
Fastman bored out throttle body - 50mm
Custom modded kegger intake
Edelbrock ceramic coated headers - 1 5/8" primaries
Magnaflow high flow cat
Flowmaster Super 40 muffler - 3" in/out
Harland Sharp 1.7 ratio rockers
Mopar cast aluminum performance valve covers
B&G Performance Flashed PCM
Split Second Air/Fuel Ratio Meter (ARM1)
Split Second Air/Fuel Ratio Calibrator (ARC1)
7.5mm Mopar performance wires
Summit cap and rotor, brass terminals
180 degree thermostat
Flex-a-lite HD transmission cooler - 32000 GVW
PML extra capacity aluminum transmission pan
Brembo slotted front brake rotors
Akebono ceramic brakes
Yukon 4.56 gears
Auburn limited-slip rear differential
17" Off-Road edition wheels from an '01 Ram
3" Skyjacker suspension lift
3" Performance Accessories body lift
Skyjacker DUL25 upper control arms
Skyjacker DLL23 lower control arms
Skyjacker 7000 steering damper
Energy Suspension polyurethane bushings
Rancho RS9000XL adjustable shocks
35x12.50/17 Toyo Open Country M/T's
Mopar bed rail caps
AVS bug deflector
Mopar running boards
Mopar side molding
Pilot fog lights
Mopar tow hooks
Diamond plate tool box
Mopar drop in bed liner
Sta-Tyte cargo net
Pace Edwards JackRabbit retractable tonneau cover
Raider Vagabond fiberglass topper
Valley tow hitch, adjustable receiver
Mopar transfer case skid plate
AutoMeter Z-Series transmission temp gauge
AutoMeter steering column gauge pod
Custom driver side a-pillar grab handle
Overhead console out of an SLT
Iggee seat covers front and rear
Rear seat sliding cup holder out of an SLT
Rear underseat cargo storage unit out of an SLT
Custom mounted Mopar "Magnum Power" grille emblem
Vinyl vertical bed stripe
2. Gav1n8 MOD List
13 inch custom RCD lift.
20 in Driv Blitz wheels.
42 inch Mickey thompson MTZs
chammilion paint job
halo headlights
chrome billet grille
shaved tailights
shaved roll pan
shaved tail gate handle
shaved door handles
limo tint.
dual 15 inch flex a lite electric fans
superchip 3815
gibson shorty headers
dual super 44 off road edition exhaust with turn downs
Airraid intake
TB spacer180 T stat
4.56 gears
Probly bunch of other stuff I can't think of but oh well.
3. zje400ex
1997 Dodge Ram 1500 4x4 with the 5.9
Mod list:
3" Rough Country lift with shocks
17x9 Dick Cepek DC-1 Black wheels
305 65 17 Mickey Thompson ATZ tires
Rancho nerf bars
K&N air filter
Power Sunroof
Tint
Sony headunit
Kicker 10" Comp Sub and amp
Remote start and keyless entry
Bedliner
4. pcfixerpro Modifications
K&N Air Filter
3" Magnaflow High Flow Cat
Flowmaster Super 44 Muffler
(Turned out before rear tire)
Flowmaster 3" Stainless Steel tip
Summit Racing Cap & Rotor
7.5mm Mopar Performance Wires
Accel Ignition Coil w/ Harness
2" Hell Bent Steel Level Kit
Pasesetter Ceramic Coated Shorty Headers
Stage 8 Locking Header Bolts
Remflex Header Gaskets
Energy Suspension Sway Bar Bushings
Rancho Steering Stabilizer
Rancho RSX Twin tube Self Adj. Shocks (Front)
Monroe Load Adj. Coil-Over Shocks (Rear)
Westin Push Bar
Baja Fog Lights
Dual 2ft cb Antennas
Uniden PC78Elite CB
Uniden Bearcat Scanner
Pendaliner Bedliner
Pioneer Sound System
Royal Purple in differentials
Weathertech Front Window Deflectors
Tractor Supply Bed Toolbox
LED Marker Lights on Toolbox
Recon LED 3rd Brake Light
Recon "Fire and Ice" Light bar
Superchips 3815 Perf. 91 tune
Painted Brake Drums - High Temp Black
Upgraded from stock steel rims to stock SLT rims
Putnam Class IV Trailer Hitch
Putnam 10,000 lb adj. ball mount
Hoppy Trailer wiring and plug mount
Window Tint - 20% fronts, 5% rear
Hitch Mount 55w Reverse lights
Custom Diamond Plate Switch Panel
Goodyear Duratrac A/T tires 265/75/16
5. olyelr MOD List
- Diesel/V10 coils in front, 2 add-a-leafs in back (for 3" of lift).
- 3" body lift
- Removed sway bar
- 35x12.5x17 BFG project mud terrains on stock off road 17x8 wheels
6. mikey0469 MOD LIST
K&N CAI
Hughes 50 mm throttle body
Harland Sharp 1.7 ration Roller Rockers
Pacesetter shorty Headers
true Dual exhaust
Magnaflow cats, Flowmaster 40 series mufflers
sct tuner
5.5 inch lift fabtech suspension
35/12.5R20 toyo MT's
fabtech dual steering stabilizers
Yukon 4.56/4.55 gears
rear auborn limited slip differential
mag-hytech high capacity axle covers
rear axle brake piston upgrade
jasper transmission
transgo performance shift kit
B&M transmission cooler
10" rockford subs and amp under rear seat
jvc stereo
tinted windows
treadbrite tool box
sprayed in rhino liner
6 peice aluminum grille inserts
treadbrite bed caps
custom mounted fog lights
180 degree thermostat.
7. Speeddemon31176 MOD LIST
1997 1500 4x4 club cab
Flowmaster true duals 2.25"with high flow cats
4" Skyjacker susp./3" body
Cowl Induction hood-non-op.
8. dodge15004x45.9 MOD LIST
16X8 dick cepek wheels
k&n cold air intake
superchips 3815
8.2mm taylor wires
20% tint on the front
cobra 29 cb with bluetooth and noaa weather
Recon "Fire and Ice" Light bar, recon cab lights
3" top guns customz lift
255/70/16 general grabber at2
All led tail lights
brass terminals
dual 4ft whips Mega Bad Ass sound system the Laramie1997 forgot...
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
__________________
Mein Kampf- Yes, I have one of my own
Is now creating sigs Look
Red Truck Club Number 7
To vote in polls
1. Member for 30 days
2. 50 or more posts!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
__________________ 1997 dodge ram 1500 360 flowmaster 40seires crager soft 8 blacks 3" pro comp lift 10x2 air cleaner oo yeah more to come oo yea its my frist truck
Ha, wow I am surprised im the first to notice the error. Chris, I think you put mikey in the running instead of max. Might want to fix that. No offense to mikey he has a great looking truck and well deserving as all of the trucks are... and if it comes down to it ill swap out if necessary.
Dang man! Yall 2nd Genners really make it tough on a guy! Hard decision. Silver you got a real impressive Mod list there but there was just something about zje400ex's truck that made me keep going back to it! Good luck to all of you guys, all great looking trucks!!
__________________
Member#005 Silver Truck Club.Dual K&N Air intake,FM catback dual exhast, Jet 180* T-stat, SC 3865,E-Fan,MSD Super Conductor wires, 5% tint all round
Eh, I'm not going to mess with it now. It's too late. I'm sure he'll get thrown back in the running a month from now. It's too much of a PITA to redo all of this now. I don't think there is a way to modify a poll that's setup already.
__________________
To vote in polls
A moderator could do it for you.
__________________ 4.56 Gears - Auburn LSD - Cherry Bomb Extreme - Nitto Terra Grapplers - Mickey Thompson Classic IIs Dodge Forum Site Moderator
