lb79theone, look for a 881 bulb it should be a 37.5 watt bulb and you can get it in JDM yellow or blue, that bulb number is the same as 896 which is stock but just is a higher watt bulb. If anyone is using the H3 bulb then you can find some 150watt bulbs on ebay and some other sites and they make the fog lamps pretty bright. I have a set of Yellow lens 6" lamps on my truck in the grille and with the 150watt bulbs they are way better then white, blue or whatever other colors you can get. Ib79theone,
Vehicle: 2001 Dodge Ram 1500 (Half ton) off road sport 5.9 liter V8 360 Magnum 4x4
Location: Maine! ( GET A HOLD OF ME IF YOU WANT TO GET ME ON FACEBOOK.COM, CARDOMAIN.COM, & YOUTUBE.COM TOO)
Quote:
YEAH! I got the HID yellow halagens off e bay. They are 881 and crosses with our 896 bulb, thats what I have. I wanted lenses too but could not find then for the 01! Are they out there? And are the bulbs your talking about more yellow then the yellow ones I have in there now!?
__________________
-2001(2nd gen.) DODGE RAM 1500 (half ton) 5.9 LITER 360 MAGNUM V8 OFF-ROAD SPORT EDITION 4x4-
Make sure you check out my profile and garage for pictures and modifications etc.!
Depends what brand did you get. The ones I was talking about are Nokya bulbs I had a set of the yellow H3 before I got the yellow lens for my off-road 6" lights, they was pretty yellow. As far as the lens go for O.E. fog lamps I would just do some research on it, I don't know of any out there but there my be some. Another thing you could try is find the same diameter of fog lamp and put aftermarket JDM yellow lens fog lamps in it.
