A 2500 and 3500 are suppose to fit, and they are suppose to be even cheaper.
"supposed" to fit and "do" fit are 2 different things. lol
is there a certain brand i should/shouldnt get? how come some say gear box and others say power steering gear box? is there a diference between them? or are they the same thing? thanks
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
__________________
black 2001 ram 1500 sport. thrush glasspack,painted black sidesteps, black windows,black headlights. cb installed,whips. black truck club member #084
Sponsored Links
Registered users do not see this ad. Click here to register for free!
check your wheel bearings, they throw off an alignment, and i think the guy might have been bull****ing you cause it sounds to me like its the wheel bearings, cause anyone who knows even a little about cars, will know that replacing a bad part with a new good part will ALWAYS make it better, unless its a defective part, then you just swap them out at the parts store, and bam.
power steering box, sounds like the pump itself. the gear box id assume is the box on the frame that your pitman arm bolts too.
hey thanks. yea thats what i thought. i didnt understand what he meant by it would only halfway fix the sloppy steering. he told me evrything else seemed tight and fine. they checked the whole front end. but when the tire is wiggled from left to right you can hear a popping noise, he said it was the gear box. this guy didnt seem all there...he looked like an older nepolean dynamite figure. lol. im not sure it would be the bearings? i mean i had all the ball joints and u-joints replaced and the bearings seemed fine at that time wich was like..2 months ago.
anyway...here is a link i found to a power steering gear box. does this look right to you guys?
__________________
bearing can go out at anytime, i would jack one wheel up, and wiggle it up and down, while looking at the u-joint, if you see any movement in the u joint your bearing is bad. then do it to the other one as well. but it really sounds to me like its the bearings. i had the same problem, bearing went out, and made for realy sloppy steering. the replaced it, and it tightend things up. but in the event that the bearigns are good, i would recomend doing the gear box adjustment diy here on the site.
and that is the gear box alright, the shaft pointing to the right is the output shaft that your pitman arm bolts to, and the other on the input shaft.
and i now stand corrected on the gearbox issue.
thanks for the info. alright ill check them out and let you know. if replacing one doesnt help then ill replace the other if i cant find out whats causing it. i wouldnt need the whole wheel bearing + hub assebly would i?
__________________
Do not replace your steering box yet. 004x1500 is hitting it right on. You've got other issues. Also, don't go back to Napolean and don't get Cardone parts.
alright thanks guys, i appreciate the info. but would one wheel bearing make the steering al sloppy/clunky? i mean i can feel it in steering wheel, and on the floor and in the peddles. its like a viabration/rattling feeling. mainly when im turning and hitting little bumps. its really annoying. but could one wheel bearing throw all that off?
__________________
i just hadd all the ball joints and u-joints replaced. so i can probably rule them out.
__________________
