DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
Thread Tools Search this Thread
Old 10-04-2009, 04:12 PM
zman17's Avatar
zman17 zman17 is offline
1998 Dodge Ram 1500
Just go out and grab the steering column right where it comes out the firewall, under the brake booster and see if there is any play. I find it hard to believe the gear box is going to cause a clunk.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
98 1500 4X4 5.2,SC3815, HS 1.7's,Borgeson shaft,
Fastman TB, Hughes Plate, 4x4 Posi-lok
Magnaflow Cat. w/Flowmaster 50 series, Rock Solid Ram Steering fix
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 10-04-2009, 04:17 PM
townsley4 townsley4 is offline
2001 Dodge Ram 1500
Vehicle: 2001 dodge ram 1500 4x4
hey, i replaced the gear box and the clunky feeling, noise has decreaed to about 60% so it definatly helped. before when i grabbed the steering shaft it was loose down where it goes into the gear. im also thinking about getting the ramfix steering shaft thing. but as for the gear..yes i can see a difference..it also made the sloppy feeling dissapear.
__________________
black 2001 ram 1500 sport. thrush glasspack,painted black sidesteps, black windows,black headlights. cb installed,whips. black truck club member #084
Old 10-04-2009, 07:43 PM
zman17's Avatar
1998 Dodge Ram 1500
The new box will make the sloppy feel go away for sure(left to right steering). As far as the clunk goes, If it's loose where the column comes out of the firewall, it's going to still clunk or pop.
__________________
Old 10-04-2009, 11:08 PM
roadney roadney is offline
Vehicle: 1997 Dodge Ram 2500 5.9l
Mine has the same clunking and sloppy feel. The shaft that connects the steering box to the pitman arms has play in it, not sure if it is a bushing or bearing that is supposed to be there but I can see it move side to side at least a 1/4" when turning. Haven't figured out the clunking but every 2gen ram I have driven seems to have it. I saw some aftermarket steering box braces and steering shafts advertised in a magazine wonder if they fix this issue.
Old 10-05-2009, 12:40 AM
Augiedoggy's Avatar
Augiedoggy Augiedoggy is offline
1996 Dodge Ram 1500
Vehicle: 96 ram ext cab 4x4 that followed me home and drained my bank account
There's a huge thread on another dodge forum about this....and there's a guy who sells a bushing to go into the steering sharft at the bottom above the spring where the factory setup has a weakness and wears. looked like a bitch to install though.. the clunk is common to our rams steering setup...
Old 10-05-2009, 08:52 AM
zman17's Avatar
1998 Dodge Ram 1500
It's a bitch to install with the column still in the truck, I took mine out to do it (1/2 hour to remove). If you get the replacement bushing from Rock Solid it comes with directions for doing it both ways.
__________________
Tags
2001, 2005, box, clunk, clunking, clunks, column, dodge, durango, intrepid, noise, ram, stearing, steering, turn, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
