I rate at 195-200 temp @ 10-75 mph
but at traffic or at the border when going to mexico It raises to 210-225
but just put it in neutral and consent rev to 2,000 rpm
I notice that depends what Coolant you use. I use green coolant I use to use the orange one but I notice that it messed up my water-pump for some reason
keep in mind I live in Houston where temperatures is 80-95 on somedays and 55-65 on others.
if you want a cooler add a aux fan and 180 thermostat and keep you fluids at check and dont add water just coolant
that only my concept
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
__________________
1999 Dodge Ram Sport- Wrecked but not out, not yet.
Sponsored Links
Registered users do not see this ad. Click here to register for free!
All Ehtyl Glycol does is raise the boiling point of water. When you raise the boiling point, you also raise the freezing temperature. It doesn't dissipate heat better than water can. IMO if you find yourself in a position where you are getting hot enough to boil water, then you have some bigger issues to deal with.
__________________
Mein Kampf- Yes, I have one of my own
Is now creating sigs Look
Red Truck Club Number 7
To vote in polls
1. Member for 30 days
2. 50 or more posts!
Agreed, imagine just running water through the block with no coolant. It would boil around the 212 Fahrenheit mark or 100 Celsius. The Ethyl Glycol in the green stuff raises that to keep the water from boiling over and causing potential damage to pumps, radiators, themostats, and possibly boiling out of the reserve tank. Normally vehicles should run between 195 and 210 F. Personally mine is just a needle width below 200, even when running heavy.
And like Laramie said, if you're boiling water, you've got issues with either radiator not dissipating heat correctly or the thermostat is stuck closed always allowing the water to pass through the block and never enter the radiator.
Plus, I believe the another point of diluting the coolant is to prevent corrosion to radiators and any other copper element of the cooling system, but I'm not sure.
__________________ 1997 Dodge Ram 1500 Sport. 5.9 Magnum/3.55/2WD. Pacer 184U & BFGoodrich 285/70R16. Go to my garage for full modification list.
Vehicle: 96 Ram standard cab, short bed, 318 auto. tranny. 87 D100, long bed, 318 auto. 87 5th Ave. 318.
The boiling point raises 3 degrees for each pound of pressure.
A 50-50 mixture raises the boiling point 11 degrees and a 70-30 mix raises it 23 degrees. That is with out pressure..
__________________
Grandpas like toys too
with a 180 tstat, mine mostly runs right at 180. if i'm towing something in the summertime, it'll climb to 200-210. i suppose its the heat coming out of the trans.
__________________
01 1500 Reg Cab 4wd 5.2 auto 3.55 285/75/16 nasta step bar tow hook sc3815 180 3923 trans cooler/filter posi-lok powertrax noslip timbren brite-box pioneer head rockford amp/speaker cobra cb firestick hughes plenum water pump timing chain oil pump rear seal front bearings brakes shocks cracked dash towing composting boat.
Mine use to be a 195 constantly. It wouldn't flinch. Lately it's been going from 195 to 215 back and forth. But then again it also won't build pressure so I gotta see what thats about.
not sure what t stat is in mine, but mine runs around 210-ish pretty consistently. doesn't matter if I'm just driving around empty, or towing a 4,000 lb trailer-it doesn't budge.
__________________ 1997 Ram 1500 Club Cab Laramie SLT, short bed, 5.2L V8, 3.55 gears, 4 speed automatic, 245/75/R16 Bridgestone Dueler APT's, HD 136 Amp Alternator, Aux trans oil cooler, factory Reese Hitch receiver, power driver seat, windows, locks, mirrors, overhead console w/compass and temp, night vision safety mirror
For awhile now, I've had mine stay steady in the 210-220 range, and many times when I'm first starting up and driving my truck I hear a pretty audible water-rushing sound coming from behind the glove box. This is because of the thermostat, huh?
