Rebuilt tranny, now it won't start! HELP!!!
I have a 2001 Dodge Ram 1500 Sport 4X4 with the 5.9, my tranny went out so i pulled it out and had it rebuilt, i got it put back in and everything hooked up now it wont start, it turns over but it wont start, also i cant hear the fuel pump running when i turn the key. also if it helps any the odometer says "no bus"! Can anyone help me or point me in the right direction? thanks in advance to anyone that can help!
reset pcm by disconnecting neg battery cable and turning on headlights for 30 sec. the headlights drain the capacitors in the pcm.
when you turn the key on, you should only hear the fuel pump whine for a few seconds.
damaging the crank position sensor is common when replacing trans. passenger side, back side of block, in the bell housing. very hard to get to.
yes/no/maybe, sort of. i missed the no bus at the end of his post.
i once had a no bus because i forgot to reattach a wad of of ground wires on the PS bracket.
its likely his crank position sensor is shorted to ground....
here's a good thread about no bus.
https://dodgeforum.com/forum/2nd-gen...ed-no-bus.html
Trending Topics
