Vehicle: 2001 Dodge Ram 1500 2WD with a 5.9L 360 Magnum
My "Rock Solid" Ram Steering Upgrade Experience
I'm sure everybody has heard of the "Rock Solid" Ram Truck Steering Upgrade. My truck has larger tires, and wanders all over the place. Well I've replaced my steering gear, hoses, and even upgraded to a steering stabilizer, but the problem still persisted. So before I started into the more expensive upgrades, I decided to try the Rock Solid fix. Got the package today, and jumped on the project. The package contained everything I needed aside of a dremel, pliers, and grease. It contained the new bushing, new retainer, and a piece of PVC pipe to install everything. The directions were VERY VERY clear. I've gotten some directions that were terrible before, but this was not an issue here. They contained color photographs, pictures of the parts you are removing, and how things should look when the new bushing is installed. Very straightforward. The removal process was a little complicated because I had no Dremel or cutting device to remove the stock retainer. So I used a pair of RoboGrips lol. I grabbed the entire spring and pulled the hell out of it, after nicking the corners with cutters. Finally broke it loose. Removed the retainer, spring, spring cup, and two other parts. Covered the ID (Inner Diameter) of the new bushing with grease and used the PVC to hammer in the new part. Then did the same with the new retainer but allowed an 1/16" gap between the bushing and the retainer. Greased everything else up and took it for a test drive. The truck feels more secured on the road, if you know what I mean. It doesn't wander like it used to, and the steering wheel feels somewhat tighter and more responsive. I also used to hear a vibrating sound when my truck was on, and the fix eliminated that.
All in all, the upgrade was a success, and a great one at that. The disassembly was a little complicated, but would have been better had I had a Dremel to cut the old retainer, but the install was easy as can be. For $60, this was a great upgrade, and definantly noticable since all my previous upgrades. Just thought I'd share!
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
Good deal. I may do this to my tow ram. It likes to wander a wee bit when loaded. I may build a stiffer leaf pack for the rear to help combat that a bit.
__________________
2001 Ram 1500 - 1450 class build in progress.
Ford Expy - CST Long Travel, 3 link rear, 34" KM2, KING/FOA Coilovers, Spooled 4.56
Quote:
Badass. If you build that leaf pack, post some pics. I'd like to look into that. Anyways, here's a pic. Not much to it
can you post a link of where you got it? i have heard of this upgrade and stuff but never really seen what it is and what is replaced.
__________________
1997 1500 4x4 5.9, flowmaster 40 turn down, rebuilt tranny and Transfer case, 2.5in lift, Ranch Hand Grill Guard, new springs and AAL, Bilstein. round air filter. Treadwright tires 285/75/16 (Look closely thats my fiance on the right )
EndIsNear:
Thanks for your install report. Sounds like you did a great job - ripping off the spring with a pair of 'Robo pliers' was a creative touch.
Our instructions suggest the 'dremel tool / small cutting wheel' method - but you've proved that isn't mandatory - ha ha ha.
I'm David Alan, the one who offers the Rock Solid Ram Steering Fix Kit, and one of y'all who ordered recently gave me the link to check out the site.
So, I took the liberty to join, so I could be of what help I may in answering any questions that arise about our Ram truck steering column related wandering / play / clunk or rattling noise issues.
I'm happy to answer how our kit fixes this congenital Ram truck Steering Column weakness - and as I've talked first hand to many Ram truck owners in the 5 years we've offered this upgrade approach, I'm also able to tell your if your steering problem lies in another area:
The steering system can be imprecise for a variety of underlying causes - worn steering knuckles, bad control arm bushings, worn track bar (4x4), stabilizer bar, bad or out of adjustment steering box, worn (or seized !) intermediate steering shaft, or lastly and usually least suspected, the Steering Column itself.
I'll post some pics to help show the column parts before & after install.
They show the manual tranny column, but aside from the shifter mechanism particulars, the Principle is the same.
For an 'after' pic on the auto column, refer3ence the pic EndisNear posted.
