DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
Thread Tools Search this Thread
  #21
Old 08-25-2009, 02:04 PM
anesthes anesthes is offline
Vehicle: 2000 Ram Laramie 4x4, 1987 Corvette supercharged
Quote:
Originally Posted by Sheriff420 View Post
if anyone still has the surge after inspecting the wire on the bottom of the valve body and a new tps or two then you should do the spark plug wire re-route procedure. mine used to surge about 300 rpm and after the rebuild it still surged about 25-50 rpm. i did the re-route and my surge went away.
here's the tsb.
http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm
Interesting. Along with the TPS, I will have to give this a try.
I've always noticed my Dodge ran kind of stumbly. If I'm off the brake, and not applying throttle it will jerk and shake a little.
light throttle cruise also is rough.. Acceleration is fine though. weird.
Between the trans failing, ball joints, leaky front dif, 02 sensors, crappy steering, and a few things I've forgot - this will be the last Dodge I own.
-- Joe
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
  #22
Old 08-25-2009, 02:28 PM
frankie27 frankie27 is offline
1998 Dodge Ram 1500
Vehicle: 98 ram 1500 5.9 liter laramie SLT QD cab 4X4
10-4 on that!!!
  #23
Old 08-25-2009, 02:47 PM
gary30mazak gary30mazak is offline
Default Tps
I had the same problem and changed the throttle postioning sensor and it cured it.
  #24
Old 08-25-2009, 09:18 PM
MrRuckuss's Avatar
MrRuckuss MrRuckuss is offline
2001 Dodge Ram 2500
Vehicle: 2001 Dodge Ram 2500 V10 4x4
i had the exact same problem, i replaced the tps and had the pcm reprogrammed and my truck runs really good, now if only i could find a donor diesel w/ a 5spd or 6spd manual.....
__________________
01 Ram - V10 - Auto - 4x4, Headers, Halo's and LED's on the rear
  #25
Old 08-26-2009, 11:23 AM
Sheriff420's Avatar
Sheriff420 Sheriff420 is offline
2000 Dodge Ram 1500
Vehicle: 2000 Dodge Ram 1500 4x4 5.2
Send a message via AIM to Sheriff420
the tps normally fixes the surge, that's why the title on this thread is "another fix..." and i offered up another fix.
__________________
I'm sorry, I can't hear you over the sound of how awesome I am.
Tags
2001, 2500, bumps, control, cruise, cruising, cummins, dodge, erratic, feels, problems, ram, surge, surging, switches, tps, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
