DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
2nd Gen Ram 1994 through 2001 Rams
Thread Tools Search this Thread
Old 09-11-2006, 08:25 PM
Red Tonka Red Tonka is offline
Default Help T-case questions
Alright boys....I was leaving the car show this weekend and the people were lining the exit so I threw the Tonka into Low Gear and hit it....little squaking and lots of loud pipes and the people were dancing to the tune of MOPAR......HOWEVER
When I got to rolling down the highway, I hear what sounded like a chaiin (the t-case chaing) rattling around almost like it was slapping the case-----This t-case is a 231 with a 4:1 Low in it from a rubicon wrangler...
Question---- I think that the 3500 and 2500 came with several different T-cases adn one of them was a 231HD which is a heavy duty...Is this true or am I dreaming....
Also, the ATLAS trans cases-- are they worth a damn or has anyone tried this????
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
Big bad Dodge: 15 inch suspension, 3 inch body, crate motor, powerdyne supercharger, 40 inch toyos, 20 inch rocker chrome wheels, whiplash kit, lots of bolt ons and 2004 Ford super duty axles with high pinion 50 (60) in front and built 60 in rear, 3.73
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 09-11-2006, 08:31 PM
jakebrake jakebrake is offline
Default RE: Help T-case questions
this should help
http://dodgeram.org/tech/specs/tranfer_case.htm
From what I've heard, the atlas's are pretty much bulletproof. I haven't owned one but I know a couple of people who have them and they swear that they are the best.
Old 09-11-2006, 09:59 PM
Socha_62 Socha_62 is offline
Atlas are amazing, but they're really only good for ya if you wheel like crazy.
__________________
DD: '97 1500, 318, 4x4
Wheeler: '91 Wrangler, Kingpin D60 Front - Lockrite, 14-Bolt Rear - Welded, Chevy 350/SM465/NP205 Currently sitting on 42" TSL's
http://www.mtu4x4.org Webmaster
Old 09-12-2006, 01:57 PM
ARbowhunter7 ARbowhunter7 is offline
Atlas II's are SICK. I just sold a Jeep TJ with one. A little overkill for your app. maybe though. Also the twin sticks can kinda get in the way. But yes some 2500's did come with the 231HD, and they're nice. If you want something tougher though, you might take a look at one of the NP241 variants from the 3500 CTD's. Tough as nails and a lot more practical than an Atlas II.
__________________
Jeremiah 29:11
2001 Ram 5.2 Auto QC Off Road
2" Top Gun Levelng Kit w/ SJ Shocks
35" BFG Mud Terrain
K&N FIPK2 w/ K&N Drycharger Cover
Flowmaster 40 Series Duals
NGK Plugs w/ Mopar wires
180 Degree T-Stat
26000# Trans Cooler
Old 09-12-2006, 03:42 PM
IS the 241 (which they also make in an HD right) a direct swap for the 231???
My application is pretty extreme so look at the gallery pics and let me know what you think???
__________________
Old 09-12-2006, 07:04 PM
I'm pretty sure that you can swap out the 241 HD for a 231 variant, but you may need a conversion kit. I took a look at your pics, and you truck's bad but I think that a 241 HD conversion might be a better choice. The Jeep that I just sold had a bored out 460, NV4500, Dana 60's F/R with OX lockers, and 38.5" Swampers running 4.88's and people still said that an Atlas II was overkill. I'd go with the 241.
__________________
Jeremiah 29:11
35" BFG Mud Terrain
180 Degree T-Stat
26000# Trans Cooler
Old 09-13-2006, 01:02 AM
Tani1500's Avatar
Tani1500 Tani1500 is offline
Vehicle: 2001 dodge ram CTD
Send a message via AIM to Tani1500
the NP 241 or 241 HD isnt a direct swap, the input shaft is longer by about a few inches. you can get it cut down to the proper size and it will work, also the NP 231 HD came in 1500 rams with a manual trans and in some 2500 LT's the rest had 241's. you also might have to get a different driveshaft with the 241 since it doesnt have a slip yoke on the t case.
__________________
2001 CTD 2500. Edge stacked with smarty, bully dog j-hook, air dog raptor 150 with half inch lines, AEM water/Methanol injection, built tranny, banks exhaust turbo back to Silverline 5inch miter cut stainless stacks, 97 dodge ram aka the beast (wheelin rig)
Old 09-13-2006, 01:13 AM
TMS Bill's Avatar
TMS Bill TMS Bill is offline
Vehicle: 98 1500 4x4 QC
Hmm ... some of the autos, too. I got one. Maybe it's the tow package again ... dunno.
Edit: Sorry, should have made it clear ... talking about the 231 HD.
Re-edit Ok ... according to the dodgeram.org link:
Transfer case versions: NV231, NV231HD, NV241, NV241D, NV241HD
The NV231 transfer case is used behind many V6 and V8 engines in pickups and sport utility vehicles.
The NV231HD, used in the 1994+ Ram with V6 and V8 engines, features larger bearings and a wider chain than the NV231. All versions of the 231 cases use three gears in the planetary reduction set.
The NV241 is essentially a NV231HD with six gears in the planetary set.
The NV241D is a heavier duty Dodge version of the 241, with a larger input shaft and larger bearings to withstand the torque of the V10 and diesel engines.
The NV241HD, an option on Ram 2500's and standard on Ram 3500's built after 1998, has a stronger case and wider drive chain to better withstand the shock of snow plow service, a PTO cover and drive gear, and an extra bearing to support the thrust to the main shaft created by a PTO adapter.
Tonka: If you can find an NV241 (not the D or HD version) it SHOULD just swap right in. There's a great spec table on the dodgeram link. The 241 looks a LOT tougher than the 231HD.
__________________
Silver Truck Club member #26
98 1500 4x4 SLT Laramie Quad
5.9L Auto 3.55 LSD 285/75R16 BFG AT T/A KO DT PROFAB Adjustable Trac Bar MP PCM Crossdrilled/slotted rotors GM 1-ton brake mod
Old 09-13-2006, 02:02 AM
So I have settled for the 231HD---- now does anyone out there have a connection for one????? I hate to buy this new, but if someone out there has a connection , I'd love to hear about it!!
__________________
Old 09-13-2006, 02:28 AM
94RAM1500 94RAM1500 is offline
Click here for one:
__________________
'94 Ram 1500 4X4. 360 Magnum.
36,000 original miles.
Tags
241, 2500, 41, 97, case, dodge, input, kit, np205, nv231, nv231hd, nv241d, nv241hd, shaft, slip, swap, transfer, yoke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
