DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
Thread Tools Search this Thread
Old 11-09-2006, 02:29 AM
mossy765 mossy765 is offline
Default power and performance
hey guys my truck is like completely stock and i want some more HP and torque and i was wonderin what kind of cheap mods i could do to git it crankin some power.......and another question i gutted my cat a while ago and my after cat O2 sensor is burnt up and i guess i need to git a O2 simm and i was wonderin how much would that increase my gas mileage since its makin it run rich right now....thanks
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
1999 Ram 2500 V8 360 4x4 144K auto tranny true duals w/ glasspacks......For Sale: $6500.00
1994 Dodge Ram 2500 cummins diesel 2wd, 5sp, sled puller 66 turbo, 50cc delivery valves, 370 injectors, val-air clutch....4K govenor springs on the way
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 11-09-2006, 12:14 PM
ASH ASH is offline
Default RE: power and performance
For free, you can modify you crankshaft position sensor (CKP). Pull it off, slot the bolt holes so it slides towards the oil filter, and reinstall. I did this and noticed a little improvement on the bottom end.
A new intake may help also. I went with the old carberator style intake, a 14 inch round model for under $30. A K&N FIPK is more expensive but popular.
A programmer will run you a little more money, you might be able to pick one up used. They won't give you as much power as a Mopar Performance PCM, which are harder to find. But you have to run premium gas with the Mopar PCM.
There isn't a whole lot that you can do cheaply to improve power. But check out my signature. The mods I did cost less than $200 altogether, and I got a noticable increase in power.
Silver_Dodge has posted quite a bit on engine mods as well as RM Indy. Do a search by putting their names in the search function.
__________________
99 Ram 1500 SLT, 4X4, Quad, Long Bed, 5.9L, 3.5 Rears, 46RE w/Shift Kit, Self-ported TB, 180 T-stat, Hypertech PPIII, 14" x 3" round air cleaner, modded TPS-CKP sensors, 100K Mi
2005 Grand Caravan Special Edition, 45K Mi.
1991 Dodge Spirit, 2.5L 190K
Old 11-09-2006, 03:05 PM
JarheadX JarheadX is offline
Send a message via AIM to JarheadX
I really want to get one of those 14' round air filters
__________________
Smoke tires. Not drugs.
0311
Old 11-09-2006, 03:26 PM
ASH ASH is offline
Here's the link for the one I used. http://www.partsamerica.com/ProductD...artnumber=1480
To install it, I found it best to pull off the TB, because I had to bend the threaded rod in an "S" shape to make it fit. It took a few tries to get the right shape, but I got the air filter assembly centered correctly. This intake has a raised base, so it clears the TB linkage. I'm pretty sure I can get a 3 inch high filter to fit under the hood. I'll try it out once this filter gets dirty.
I have a picture of it installed on my truck, check out my gallery.
__________________
Old 11-10-2006, 07:43 PM
dirty dog dirty dog is offline
what would cutting the crankshaft position sensor do?
__________________
Dem Ol Dodges Go Everywhere
2000 off road package
5" suspension
3" body
leveling kit
dual 2.5 inch straight pipes
37" mickey thompson baja claws on 15x10 chrome rims
hypertech programmer
yukon 4.88 gears
much more on the way SOON
Old 11-10-2006, 07:48 PM
silverram99 silverram99 is offline
Send a message via AIM to silverram99
Quote:
ORIGINAL: dirty dog
Slotting it will allow you to advance the ignition timing some. Just like advancing the distributor in the old days. You cannot advance the timing from the distributor on our trucks, so basically by bumping the timing using the CKP sensor you can "fool" the computer.
__________________
Smurf Yeah
1999 Dodge Ram 2WD 318/Auto
S&B CAI
MSD 6A
Blaster 3
180 T-Stat
Flowmaster 40 2.25 Dual Outlet
Accel 9mm Plug Wires
Self P
Old 11-11-2006, 01:40 PM
Works4Ford Works4Ford is offline
Wouldn't slotting the crank position sensor and turning it also affect when the injectors pulse?
__________________
'01 1500 Off-road RC SB. 2" coil spacers, 3" body lift, 35" BFG Mud Terrains
'95 Mustang GT 347ci
Tags
diesel, disel, dodge, performancecom, repower, sprinter, wwwdodge, yukon
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
