I have a 1999 1500 318 4x4 , I have water leaking out a hose coming out my firewall on the passanger side when I run the heat is this a bad heatercore and is it a hard job to do at home. Please Help....
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
I paid to have mine replaced this summer it is impossible to do in the home shop. I believe it requires taking the entire dash apart possibly taking out the windshield. Me and my dad tried to do it ourselvesspent all day cramped trying to figure out why someone would design something that was this imposible to do your self.
__________________
2001 Dodge Ram 1500
Standard Cab
5.2L V8 5spd
Superchips Max Micro Tuner
Flowmaster Cat Back Duel Exhaust
40 Series Flowmaster
Fram Boost Cold Air Intake
83,000
It could be a couple of issues.
1st. It could be the condensate line to drain as it does more with the A/C running.
2nd. It may be the hose clamp loosened over time and justneed to tighten or replace.
3rd. Hose could have a hole in it and needs to be replaced.
4th. Your screwed and the heater core is bad. They will usually leak in the floor when they go bad. If it is leaking outside than it is probably a connection problem.
This is my opinion from past experience and not meant to beprofessional advise.
__________________
97 1500 Sport 5.9 Auto, 3" PA Body lift 4.56 Gears, 37x13.5x15 Claws on 15x10 rims, Flow Master, 2 MTX Amps, 4 Infinity's & 2 MTX 10's
3" Rancho lift coming off, 6" Dick Cepek lift in progress.
"Buy American, It Might Just Be Your Job You Save"
