DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
Thread Tools Search this Thread
Old 12-13-2007, 02:51 PM
BradBeyer's Avatar
BradBeyer BradBeyer is offline
Default RE: adjusted steering box - removed play in steering
actually that fixed the pulling to the left but I think I have it to tight because it seemd like it does have a little bit of a memory
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
- 2007 Dodge Ram 1500 4x4 w\ Hemi - Big Horn Edition - Flowmaster super 44 - Front leveling kit
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 12-13-2007, 10:16 PM
ryans590 ryans590 is offline
if it feels like it has a bit of a memory then loosen it off just a little, or it will ware out the steering box faster
__________________
^^ sorry for the poor spelling
1998 Dodge Ram 1500 4X4 318 (5.2L)
too much to list....
Old 12-15-2007, 12:58 PM
charlie1935's Avatar
charlie1935 charlie1935 is offline
Vehicle: 96 Ram standard cab, short bed, 318 auto. tranny. 87 D100, long bed, 318 auto. 87 5th Ave. 318.
Jack the front end up and turn the steering whel back and forth, if you feel a tight spot back the adjustment just enough that you can't feel it.
__________________
Grandpas like toys too
Old 01-17-2008, 11:47 AM
kowboydmac kowboydmac is offline
Had an adjustment and my arm's replaced; still need to do the TRE but my steering wheel has a lot of play. Should i try this even though I know the TRE are OK at best?
__________________
1996 1500 2wd 360.
Never Satisfied. Always Gratified.
Old 06-04-2009, 11:00 AM
Ram80 Ram80 is offline
Vehicle: 98 Ram RCSB 5.9 3.55's
I have a 98 and i can't see anything to ajust under the steering box, can you take a picture or are the 98's different?
Old 06-04-2009, 11:11 AM
Optimus Optimus is offline
Vehicle: 1998 Ram Sport Quad Cab 4x4
The adjustment nut is not under the steering box, it's on top. I tightened my '98 up about a month ago and it helped a LOT. Personally, turning the wheels back and forth while not moving did not reveal any "hard spots" but I still overtightened by about a 1/4 turn. Total amount I ended up turning the set screw was about 1 1/2 turns (lefty loosy righty tighty). I had to take it for a drive first to realize it was too tight the first time. I wouldn't call it memory, I would simply call it fighting against whatever you try to do. It doesn't want to turn, it doesn't want to go straight, it doesn't want to return to center on it's own. No "hard spots" though.
Old 06-04-2009, 12:02 PM
Thanks, the DYI stated to do it from underneath so i assumed it was on the bottom(see what happens when you assume) again thanks!!
Old 06-04-2009, 04:57 PM
I think the DYI meant you end up having to be under the truck to do it. I don't see how I could have done it from up top. Too long of a reach to try to get the nut loose. It's easiest to lay on your back or on a creeper looking up. I used a regular box wrench (forget exactly what size, but I think it was 15, 16, or 17mm), and I used a regular allen wrench (forget the size on that one too, but I think it was around 5mm). FYI--the allen head was full of gunk when I did this procedure to mine. I had to take a much smaller allen wrench (a paper clip would be fine too) and dig the crap out of there before the allen wrench would actually fit. It was pretty much packed full of crud.
Old 08-07-2009, 09:49 PM
btobin's Avatar
btobin btobin is offline
So will doing this adjustment help me if my steering is extremely tight turning right and normal going left?
Old 08-13-2009, 09:57 PM
Maxx_Magnum's Avatar
Maxx_Magnum Maxx_Magnum is offline
1998 Dodge Ram 1500
Vehicle: 98 Dodge Ram 1500 4X4
Quote:
I'm willing to bet your steering stabilizer shock is bent.... I bent mine mudding one day bad enough that it wouldn't turn to the right at all, but would still turn left. pull it off and see if that fixes the problem
edit: nvm just saw your thread about this
__________________
1998 Dodge Ram 1500 4X4 QuadCab 360ci auto
Tags
03, 2001, 51, 70, 95, adjust, adjustment, box, challenger, dodge, play, ram, screw, steering, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
