DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
Thread Tools Search this Thread
  #21
Old 10-15-2009, 01:18 AM
woodro350 woodro350 is offline
Default 1999 Ram 4x4 1500
Hello,
I have a 99 Ram 1500 4x4 Reg Cab Short Bed.
It had the stock size tires and 16" rims on it when I got it. It had alot of play in the steering. I got a good deal on stock size 20's 275/60-20 and put them on.
Later the tranny went out so I took ot to Aamco to have the tranny rebuilt. While it was there I told them about the steering play and they said the box needed replaced too and all my other steering components were like new. So I told them to replace the box.
Heres the deal:
There is still about about 3" play in the steering wheel and also the steering is stiff and wont return back to 0 when let go while driving down the road, Also when the truck drifts to say the right...you can correct it by going to the left and it will hold that posisition and then you turn it back to the right it will hold that posisition also, They told me it was all because of the oversized tires.
My first thought was they didnt change the box and they tried removing the slop by adjusting the box and over tightend it at the same time. But I did look and all the signs are there that the box is actually a different box. It looks brand new and the bolts look like they have been removed and re installed. Its also marked Remanufactured.
They told me they got it from Advance Auto.
Whats strange is how the box is acting with it being a new reman box. It seems like the gears are so worn out in the box that by adjusting it to the point where its hard to turn and its real sloppy is what they had done.
Im taking it back on friday for them to replace it again.
Whats do you guys think.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
  #22
Old 10-15-2009, 08:24 AM
dhvaughan's Avatar
dhvaughan dhvaughan is offline
Vehicle: 01 1500 4wd
welcome to df. the search feature seems messed up again, but there's a few threads in the past from forum member zman1 about his experience replacing steering boxes. he went through 2 or 3 bad ones before he got a good one. seems like it was a couple of dormans that were bad out of the box and finally a fenco that was good. seems odd to me that a steering box company can't rebuild and test a steering box, but it does seem to be somewhat common.
__________________
01 1500 Reg Cab 4wd 5.2 auto 3.55 285/75/16 nasta step bar tow hook sc3815 180 3923 trans cooler/filter posi-lok powertrax noslip timbren brite-box pioneer head rockford amp/speaker cobra cb firestick hughes plenum water pump timing chain oil pump rear seal front bearings brakes shocks cracked dash towing composting boat.
  #23
Old 10-15-2009, 11:37 AM
zman17's Avatar
zman17 zman17 is offline
1998 Dodge Ram 1500
Those were Cardones that were bad, which is what I think Advance sells. Most companies reuse the old valve body, and I think that is the flaw. You should also check the intermediate shaft ujoints and slip joint for play.
__________________
98 1500 4X4 5.2,SC3815, HS 1.7's,Borgeson shaft,
Fastman TB, Hughes Plate, 4x4 Posi-lok
Magnaflow Cat. w/Flowmaster 50 series, Rock Solid Ram Steering fix
  #24
Old 10-15-2009, 03:25 PM
Relex Relex is offline
Thanks for the tip, I'll have to give it a try after this snow stops.
__________________
  #25
Old 10-15-2009, 04:43 PM
zman17's Avatar
1998 Dodge Ram 1500
BTW, if it was returning to center, right before you changed it(without replacing anything else at the same time), it's junk.
__________________
  #26
Old 10-16-2009, 10:10 AM
mnewbolds mnewbolds is offline
1995 Dodge Ram 1500
Vehicle: 1995 Dodge Ram 1500 4x4
Question
Quote:
Originally Posted by Maxx_Magnum View Post
I'm willing to bet your steering stabilizer shock is bent.... I bent mine mudding one day bad enough that it wouldn't turn to the right at all, but would still turn left. pull it off and see if that fixes the problem
edit: nvm just saw your thread about this
I was at a shop and the mechanic said I was better off just removing the steering stabilizer all togather. He also said his truck had gone through them so fast he was sick of replacing them. Here in Michigan we have some roads that'll rattle the teeth outa your head. Have you heard of this being done and if so. Does it help?
  #27
Old 10-18-2009, 10:59 PM
Quote:
Well I had Aammco put the 2nd Advance auto parts steering box on and its alittle better as far as slop. I now have 2" slop from right to left instead of 3". These guys down there dont know what there doing on top of that cause they still insist that there is nothing wrong with the box and keep saying its because I have current factory size rims and tires on it.
275/60-20. I tried telling them that that doesnt have anything to do with slop in the box. They said well we called Michael tire plus and also expert tire and they told them its because of the 20's too. (Where do these people come from?)
OR AM I WRONG??? Even though the 2nd box is a inch better then the 1st new box.
  #28
Old 10-19-2009, 03:11 AM
Ramman18 Ramman18 is offline
You're not wrong. You're just using the wrong brand. I've never read a story where any gear box from a regular parts store works perfect. Check out Redhead Steering as they completely rebuild with better internals. Mechanics don't know crap anyway.
__________________
1999 1500 4x4 Xcab SB 318 nv3500 hypertech PPIII
180 stat Champion Truckplugs 4071
Flowmaster 50 Magnaflow Cat
Nitto Terra Grappler 285/75 R16 Thuren track bar
  #29
Old 10-19-2009, 06:37 PM
scottnfwi scottnfwi is offline
Vehicle: 1995 dodge ram 4x4
Does it help in streighting out the steering wheel also?
__________________
1995 ram 1500 4x4 larimie slt with a 3 in. lift
  #30
Old 10-19-2009, 06:53 PM
zman17's Avatar
1998 Dodge Ram 1500
No, but that's easy enough to fix.
__________________
Tags
03, 2001, 51, 70, 95, adjust, adjustment, box, challenger, dodge, play, ram, screw, steering, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
