Last edit by: IB Advertising
Browse all: Cooling System Guides
- Dodge Ram 2002-2008: How to Replace Thermostat
Step by step instructions for the do-it-yourself repairs
Thermostat Install DIY
Well just got home from a day of driving. Things I have noticed. Pretty much no difference. Heater still blows just as hot. The engine seams to run better, but I also changed spark plugs from 5224, hard to tell if there is more power because the roads are still really slick.
I used a dremel to make the notch, but a small hand file would work. The notch does not really need to be perfect, just enough to clear the o-ring notch.
I have not heard anything about the 160, but 180 would be as cold as I would go on a my truck. 160 seams way to low, if the engine had a carburetor you might get away with it.
The water pump is nothing special that I can tell, the propeller looks almost the same as stock. The reason for my change was the bearing was going.
Cooler engine to an extend is a happier engine. Every 10 degrees you drop the engine temp is good for 1HP, So nothing major
