05 Dakota with engine Tick, Stops at 1500 rpm in gear
So I Just got a 05 Dakota 3.7 v6 42rle auto trans, bought it with engine tick not really a knock doesnt sound like a spun bearing. noise is there all the time in neutral. Noise slightly gets faster sounding with raising of rpm's, but when engine is in gear, reverse or drive and you get it up to around 1500-1700 rpm noise disappears completely, but noise comes back after the 1700 ish rpm mark. Any ideas? Truck has high miles just over 200k it had a bad #3 coil pack causing a miss fire but fixed that. now I really want this noise gone before it gets any worse. It needs a oil change real bad that's my next step, just wondering why the noise goes away in a certain rpm range and only when in gear. If I'm in Park or Neutral and raise the RPM's its still there only goes away in gear, and yes I'm positive its the engine and not the tranny making the noise and it sounds like its coming from the driver side if looking under the hood can't tell if its upper or lower end kinda sounds like lower end but not 100% sure. Oh yeah took that valve cover off to see if anything was loose and everything was tight for the most part and no metal shavings or anything like that in the oil.
Sorry for the run on sentences and poor grammar I hate typing lol
Trending Topics
If nothing else, I would look for broken exhaust manifold bolts/studs and signs of an exhaust leak around each cylinder head.
The following users liked this post:
BEMOUSE86 (02-08-2022)
