Front and Rear Axle fluid change.
#21
RE: Front and Rear Axle fluid change.
HELL YEAH...I used that in my 96 dakota that was given to me by my father with 35,000 miles on it and I had to get a new radiator because of scale build up and i put the new radiator in and the next time i changed my radiator fluid in i put that bottle in and i had the truck up to 145,000 miles and it still had the original waterpump and the radiator was fine. I've used it in pretty much all my vehicles and never had any problems with it...it actually made my truck run cooler! don't know how but it made it run about 20 -30 degrees cooler. So its never done me wrong...and really why dodge says that is because the coolant that dodge provides is known to build up scales in the radiator after about 20,000 miles thats why i change it every 20,000 miles religiously....i've been with dodge for many years and have learned alot of things that really dodge will not release to the public! so yeah i would recommmend using it...and i follow the fluids above that i posted religiously and none of my cars have failed on me.
#22
What brand coolant do you use? At 30,000 miles I plan to change both front and rear diffs and flush the radiator and all the other fluids. Does royal purple make coolant and tranny and transfer case fluids for our trucks? Last time I checked they didn't have the transmission fluid which goes in most of the stuff on our trucks.
#23
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API*
SAE 0W-30 Synthetic Signature Series Oil
SAE 5W-30 Synthetic Motor Oil
SAE 5W-30 XL Synthetic Motor Oil
All Temps......5W-30
Manual Transmission,Getrag 238.....AP4
Synthetic Automatic Transmission Fluid
Automatic Transmission.....AP4[1]
Differential, Front C205F.....GL-5
All Temps......75W-90
Severe Gear 75W-90
SAE 75W-90 Synthetic Gear Lube
Severe Gear 75W-110
Differential, Rear 8.25-9.25 Axles.....GL-5[2]
All Temps......75W-140
Severe Gear 75W-140
SAE 80W-140 Synthetic Gear Lube
Transfer Case,.....AP4
Fluids
Power Steering Fluid.....AP4
Brake Fluid.....HB
Clutch Fluid.....HB
CHASSIS LUBRICATION
Two-wheel drive
6 Fittings, 0 Plugs..........LB
Series 2000 Synthetic Racing Grease
Synthetic GHD Heavy-Duty EP Grease
Synthetic Multi-Purpose Grease NLGI #2
Four-wheel drive
17 Fittings, 0 Plugs..........LB
CAPACITIES
Engine, with filter..........6.0 quarts[1]
Cooling System, Initial Fill..........16.0 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, 545RFE 2WD Initial Fill..........5.5 quarts[2][3]
Automatic Transmission, 545RFE 4WD Initial Fill..........6.6 quarts[4][5]
Automatic Transmission, 4-Shallow Paneed Initial Fill..........4.0 quarts[6]
Automatic Transmission, Total Fill
42RLE..........8.8 quarts
4 speed 545RFE..........14.0 quarts
Manual Transmission, Getrag 238..........4.6 pints
Differential, C205F Front..........3.6 pints[7]
Differential, with 9.25 ring gear Rear..........4.5 pints[8]
Differential, with 8.25 ring gear Rear..........4.2 pints[9]
Transfer Case,NV244..........2.7 pints
Transfer Case,NV233..........2.3 pints
1. After refill check oil level
2. With ENG at operating temperature, shift through all
gears. Check fluid level in NEUTRAL and add fluid
as needed.
3. DTC'S may be set , reset W/ DRB III, if necessary
4. With ENG at operating temperature, shift through all
as needed.
5. DTC'S may be set , reset W/ DRB III, if necessary
6. With ENG at operating temperature, shift through all
as needed.
7. Fill to level of fill plug.
8. Fill no higher then 5/8" below plug hole.
9. Fill no higher then 1/4" below plug hole.
TORQUES
Oil Drain Plug.....25 ft-lbs
Transfer case
Fill Plug.....15-25 ft-lbs
Drain Plug.....15-25 ft-lbs
Manual Transmission Getrag 238
Fill Plug.....37 ft-lbs
Drain Plug.....37 ft-lbs
all available on my site
Engine Oil
Grade 1......API*
Severe Gear 75W-90
Severe Gear 75W-110
Severe Gear 75W-140
Fluids
Brake Fluid.....HB
Clutch Fluid.....HB
CHASSIS LUBRICATION
Two-wheel drive
Four-wheel drive
CAPACITIES
as needed.
as needed.
as needed.
TORQUES
Transfer case
#25
#26
Am I reading this correctly? A 4x4 has 17 fittings that need to be greased[:-]? Where the heck are they?
CHASSIS LUBRICATION
Two-wheel drive
Four-wheel drive
Two-wheel drive
Four-wheel drive
#28
ORIGINAL: graythang
I was told by my dealer that for the 15k service that included transfer case additive, LSD fluid change they wanted over $400.00. Yah, right! This is not a hummer or some exotic. I will either do it myself or have Jiffy Lube do it.
Also, dealerships make their money on "Sevicing a vehicle" andnotselling aNEW vehicle. If you know anyone that works for a dealership, they will tell you the same, and if they don't then they haven't seen the "books."
#29
#30
