DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Dakota > 3rd Gen Dakota
Thread Tools Search this Thread
Old 08-08-2008, 05:22 PM
LB's Avatar
LB LB is offline
Vehicle: '05 Silver QC Laramie 4x4
I am wondering if you use one of those special tools the fitting comes out of the bulkhead, and it stays in the radiator. Seems like not a good design if that's how it works. I bought one of those tools but could not get the fitting out so I started to remove the bulkhead fitting and antifreeze came out.
LB
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
V8, Auto, LSD, tow
Mopar underrail bedliner and bed rail caps
K&N Air Filter
2" TM level kit
07 Chrome RAM 20's
265/50/20 Bridgestone Alenza'a
Transgo 545RFE -HD2 shiftkit
R/T hoodscoop or deepthroat hood next
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-24-2008, 05:55 PM
LB's Avatar
LB LB is offline
OK Boop,
I figured this out if you haven't already. Just slide the white protector back, take a small screwdriver and pop off the clip and the hose comes right out. I feel pretty stupid as I wish I had the patience to figure this out when I did my trans filters and shift kit. I thing the design is strange as the bulkhead fitting seals the antifreeze side, so if it comes out does the antifreeze and trans fluid mix?
Somewhere around 17K I went from 17MPG to about 15.9, at 27K I put in new plugs, changed all fluids to AMSOIL (except trans) trying to get the mileage back with no change. At 30K I did both filters and a transgo kit, it took 8 qts mopar ATF+4 (would have done the rest if I could have gotten the trans line off). Since then I gained a consistant 1.5MPG increase to 17.5+ combined driving, I can't justify either the shift kit or the 8qts transfluid, but something worked...
My quandry at this point is do I drain my pan change filters again (they are very cheap at bulkparts.com) and change the rest of the fluid for a full change or do it next year.
Just my 2 cents
LB
__________________
V8, Auto, LSD, tow
K&N Air Filter
2" TM level kit
07 Chrome RAM 20's
Old 08-27-2008, 06:29 PM
Dobbie1950 Dobbie1950 is offline
Junior Member
Default Trans Cooler
I installed a aftermarket trans cooler on my 05 Dakota last year. The fittings on the radiator seal both the water jacket and the cooler line. The best thing to do is cut the hose on the drivers side and splice into it. I got my fittings at home depot, after searching three auto parts stores. havn't had a problem yet. Just remember to run the new cooler through the radiator cooler, this warms the fluid in the winter time.
Tags
1969, 545rfe, aftermarket, cooler, coolers, dakota, dodge, radiator, roadrunner, rt, size, thread, tranny, trans, transmission, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
