If you come across an aftermarket that is cheaper than the OEM part, please post it up. This seems to be a fairly common issue now that more guys are hitting higher miles...
Yah, let us know. I have the same problem, ruff idle since new, but seems to be getting worse 32K miles. If I an stopped and start rollong slowly with the brake on the truck pulsates, Dealer says he can't do anything unless it throws a code!
LB
__________________
'05 Silver QC Laramie 4x4
V8, Auto, LSD, tow
Mopar underrail bedliner and bed rail caps
K&N Air Filter
2" TM level kit
07 Chrome RAM 20's
265/50/20 Bridgestone Alenza'a
Transgo 545RFE -HD2 shiftkit
R/T hoodscoop or deepthroat hood next
I got a 06 crew cab with 12K on it and it also suffers from rough idle. I took the truck to the dealer and they replaced all the valves just like the service bulletin says and when i got the truck back the idle is no better still rough just like it was. My main question is will this cause some trouble down the road when the truck gets older.
Installed new tps today and reset computer. Idle is the same if not a little worse. The new unit has a voltage of .75? What the hell? Wish i never bought this thing now. Should have stuck with the blue oval!
