DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Dakota > 3rd Gen Dakota
Thread Tools Search this Thread
Old 10-24-2008, 06:55 PM
JHAAF JHAAF is offline
Vehicle: 2006 dakota quad cab 3.7
Default Rough idle still.
okay guys i need a little advice. I have a 2006 dakota quad cab. It has the 6-banger in it. The truck idles terrible. It is really noticable but, the tach stays still. I have read many posts on hear as to this problem. The computer has already been flashed as the idle is around 700. Brand new plugs in are the Autolite 5224's. I need some help!
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 10-24-2008, 08:11 PM
x99j x99j is offline
Vehicle: 2006 dakota 3.7 manual trans
i have the same issue (with 06 3.7L). i initial used 5224 autolites and the rough idle continued. but as soon as i am out of warranty i am going to put some 3923 autolites in. alot of people on here have had luck with those. because they are one temperature lower.
for some reason, up to 05, 3923's were the o.e. replacement for the 3.7L, but in 06 dodge changed the plugs to one range hotter? some say it was to combat carbon build up on the valves that plagued a few 3.7L's in the jeep libertys? who knows?
also there is a tsb on 05-06 3.7L's with a rought idle. i have the link below. mine does not qualify for the tsb because i have no misfire count at idle. mike
tsb link:
http://www.dodgeforum.com/forum/show...ght=rough+idle
Old 10-24-2008, 08:13 PM
superdak05's Avatar
superdak05 superdak05 is online now
2005 Dodge Dakota
Vehicle: 2005 dodge dakota
first off, the 5224 are not that great of a plug to run in these motors. they like the 3923 autolite. also check you vaccum hoses. they may seem fine, but might be cracked around the fittings. could have a cam positioning sensor going. thats on the side of the block on the passenger side.
__________________
thats right i did it ,so what, cry two tears in a bucket, f@#$ it, lets take it to the stage
13.7 / 101.3 in the 1/4 mile
Old 10-24-2008, 08:14 PM
also the second time i went in for it they re-flashed my pcm with the latest software. what it did was up my hot idle from 500 to 600. it helps a little but still is rough.
Old 10-25-2008, 12:20 AM
superdak05's Avatar
2005 Dodge Dakota
the other thing to do is reset the computer. disconnect the neg. battery cable. then turn key all the way to start. hold for 20sec. reconnect battery cable. start and stop truck 3 times. on the thrid time leave truck running for 5 min. it will need to relearn the paramiters. take truck for a ride. if it still dose it. then your throttle position sensor needs to be replaced. about 106.00
__________________
Old 10-25-2008, 03:19 PM
Default superdak05
Do you know what the voltage is supposed to be on the tps?
Old 10-25-2008, 05:54 PM
Default Still!
I did the battery thing and no change. Anymore suggestions? I would like to know the tps voltage before i go wasting some cash.
Old 10-26-2008, 12:37 AM
superdak05's Avatar
2005 Dodge Dakota
i dont remember when we did mine. but i think it was 7 volts or something close. i know there is a write up some where in one of the threads.
__________________
Old 10-26-2008, 05:43 PM
Default tps?
I looked in the manual on here and it states 5 volt supply with .29 at idle. I checked mine out and it is around .65 volt. Maybe it. A little mad it is not adjustable like my mustang though. I guess this is the problem? It has done it since i bought the truck. Just seemed to be getting worse. Didn't have the time to get it to the dealer before warranty ran out. Sound like the right thing to do?
Old 10-26-2008, 08:52 PM
ericemery's Avatar
ericemery ericemery is offline
Dodge Forum Administrator
2006 Dodge Dakota
Vehicle: 2006 Dakota Quad Cab
Send a message via AIM to ericemery Send a message via Yahoo to ericemery
well, it is a start. You can at least eliminate it as the cause.
__________________
-Eric-
DodgeForum.com Administrator
Tags
04, 229, 37, 47, buick, dakota, dodge, fire, firing, idles, odd, order, rough, semieven, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
