DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Dakota > 3rd Gen Dakota
Thread Tools Search this Thread
Old 09-02-2009, 08:54 PM
biker_ahoy biker_ahoy is offline
2007 Dodge Dakota
Vehicle: 07 dakota quad cab 4x4
Default Front end Squueking when on bumpy surfaces easly make noise
Front right is squeaking and making noise with every movment on the front end,
its something to do with the suspention or a moving part, little bumps make noise too. ???
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 09-02-2009, 09:41 PM
snipingdude snipingdude is offline
2005 Dodge Dakota
Vehicle: 2005 Dodge Dakota SLT
Send a message via AIM to snipingdude
same here man...ive pretty much narrowed it to a bad shock...
Try this....go outside and open your windows and grip the handle bar from the inside and pull back and forth....rock the truck and see if you have any squeaking...thats what i have
__________________
Old 09-02-2009, 10:24 PM
motodeficient motodeficient is offline
My 05 has started doing this in the last week from the drivers front. Im thinking its the shock. My passenger swaybar link broke and I was hoping it was just the drivers side swaybar link going bad from trying to compensate. But I replaced both links today and the noise is still there.
Old 09-02-2009, 11:00 PM
2005 Dodge Dakota
Yeah like I said too I also think its a shock for me...whenever I rock the truck from the outside i can hear it coming from the coil area behind the rotors
__________________
Old 09-02-2009, 11:52 PM
kartoon713's Avatar
kartoon713 kartoon713 is offline
Vehicle: 2007 Dakota SLT 4.7 (Black)
It sounds like control arm bushings going bad. Does it squeak while your truck is going straight or only when turning?
Old 09-03-2009, 02:08 AM
marker227 marker227 is offline
Vehicle: 2005 Dodge Dakota SLT Quad Cab 4.7 4x4
Mine does it when I just go straight.
Old 09-03-2009, 02:13 AM
2007 Dodge Dakota
straight and turning.
Old 09-03-2009, 07:31 AM
sdsdsd sdsdsd is offline
The front struts are known to be crap!
Old 09-03-2009, 11:19 AM
MonkeyWrench4000's Avatar
MonkeyWrench4000 MonkeyWrench4000 is offline
Take off your front wheels, its that simple, have a look first. Maybe its a broken end link? If its causing a rub, that will make a squeek, also visually inspect everything else you have knowledge on. Then give it some flex, have a listen. You will find it.
There isnt THAT much going on up there.
STRUTS is the most expensive guess to take lol. I'd try to find out first. Considering end links are like 25 bucks, and control arm bushings are like $5. I wouldnt just go straight for the struts until i was really sure.
__________________
06 Dodge Dakota ST 4x2 V6 3.7L
KYB Rear Shocks, 265/75 BF Goodwrench ATs
Old 09-03-2009, 12:33 PM
mprohr's Avatar
mprohr mprohr is offline
2006 Dodge Dakota
Vehicle: '06 Dakota HO QC
My ranger had that same problem. It was a bad ball-joint. Open the door and use it as leverage to rock to truck. Have a friend do the rocking while you are underneath diagnosing the problem.
Tags
2007, 95, bumpy, bushings, dakota, dodge, end, front, frt, making, noise, squeaky, squeek, squeeking, truck, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
