Security light constant on, no lights, no start, NOTHING
HELP HELP HELP!
My security light is on on the dash - constant, not blinking. It goes a little dim when i put the key to run position.
NO other lights come on, no radio, no dome, NOTHING
At first thought it was a dead battery - tried jumping... NOTHING
Then I started thinking about that light - it seems to stay on, and jumping didn't even turn on the dome lights or ANYTHING
Took cable off of battery, let it sit for like 5 minutes, put back on - nothing
Checked all fuses, they all seem to be good.
HELP I need this truck running so i can get to work monday!!!
Edit: Found elsewhere that taking off negative cable and putting key to "start" position for 15 secs, then reconnect battery should reset alarm.... didn't work either
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
__________________
2005 QC 4x4 4.7 - STOCK, HELP!
Reason: Found info on resetting alarm
Sponsored Links
Registered users do not see this ad. Click here to register for free!
Well, found out the problem....
Although i was trying to JUMP the truck, it didn't work because the battery was really really dead, and my wife's car just couldn't give me enough juice to get it running.
Battery tester said i basically was holding 4 volts.... yeah... not good
Yeah, I was going to say that the caliber had a similar issue after sitting. the battery had a bad cell and wouldnt hold a charge. the security light was on.
