Wideband Finally Installed
on
1 Post
Finally got the Wideband Commander installed a couple weeks ago.
Seems like some of you guys were asking about a pillar pod for our trucks. In case someone else wants to try it, I thought I'd post this to show how I did mine. I used the universal single pillar pod from Glowshift Direct. Used a heat gun to form it, very slowly or you'll waste the pod like I did the first one. Plastic adhesive to stick it to the pillar post. Make sure you use a plastic adhesive that works on PP plastic, I used Loctite plastic adhesive. I then took it to a body shop and they blended it in with some kind of plastic putty and sanded it ($40.00). I textured and painted it. I used Sem texture coating to texture it and SpectraMatch trim paint from DieselManor to paint it. I used Mopar Natural beige, part #SM-D128AA. Came out pretty good I think. The texture is not an exact match to the other side but really not noticeable unless you're looking for it.
The WBC works exactly as advertised and the install is a snap as long as you're careful and follow the directions.
http://i216.photobucket.com/albums/c...t/IMG_3507.jpg
http://i216.photobucket.com/albums/c...t/IMG_3509.jpg
Guest
Posts: n/a
on
1 Post
Eric, I got the Dynojet Wideband Commander from Air Ram.
I'm also doing some research on a turbo, l assume you're looking at an STS? PLease post up any info you come across!
Seeing how it's a universal kit, my biggest concern is the install cost.
BTW you can get an SCT "canned" tune without a wideband but if you go with a turbo I think a custom tune would be a necessity.
Guest
Posts: n/a
Well, I have made a few calls around... and its looking like a remote turbo is probably the way I am going. I talked with a guy at STS about my power goals. I should be able to accomplish what I want with a single turbo setup. for a faster spool up, going with a twin turbo set up with smaller turbos would be the way to go. I am going with a single, for my sanity's sake...
I am waiting on a reply from hemifever on the tuning side of things... I doubt I move on the turbo this year, since we are buying a house. but I may possible try to start the project this winter... depending on some other variables.
on
1 Post
