Seat Cover Removal
Seat Cover Removal
Can anyone tell me how to remove the front seat covers?? I have a 05 with heated leather seats, and am wanting to replace the drivers side cover with a new one (all ripped up). I am getting a used cover from a salvage truck.
Is there a way to remove the seat covers without taking the whole seat out of the truck. With all the wiring and crap under the seat, I want to do the least amount of work as possible.
I've heard somewhere that there are like 6 "clip like things" the hold the cover on but dont want to screw anything up.
Any info from someone who's replaced a leather cover or put in a leather cover on there's to replace a cloth one would be great!
Thanks
MoparPower00
Thanks
MoparPower00
I haven't taken any Dakota seats apart, but have taken apart Jeep and Chev Truck seats and they all take a fair amount of dismantling to get to the point where you can take the upholstery off. All the plastic needs to be removed (sometimes it's popped on, othertimes it has screws - a trim removing tool set is good to have), and then you can get to the point of undoing the upholstery fastening. This fastening is generally some type of ring, like a round split chain link. For the few seats I've taken apart, I've had to remove the seats from the vehicle to do this, so if you can get some seats just like yours that are in good shape, I'd recommend swapping them - you just need to deal with a few bolts and connectors and it takes a lot less time.
remove tilt handle from the seat and look under the back of the backrest on the bottom of the seat there is a black plastic tab that is the width of the seat that slides into another plastic piece. You will have to pull this apart. there is a similar setup between the backrest and the seat cushion. If you undo these clips you can slide the material off the seat and replace it. A trick is to put a plastic bag between the foam and the cover to make the foam slide back on easier.
if all else fails look in the service manual. there are diagrams https://dodgeforum.com/forum/3rd-gen...s-manuals.html
