bull bar install HELP
2007 dakota
Hi guys, back at work in the shop this thing is driving me crazy.
I loosened the screws (all 4) but they seem to just be turning and not coming out. Im talking about the 2 big ones that are vertical (body mount screws?)
Is there a nut on top of there somewhere? I can't feel one up there.
Thanks.
Thanks.
16th post down is what I had to do to get em loose...
https://dodgeforum.com/forum/3rd-gen...hts-oh-my.html
2007 dakota
Thanks.
Thanks.
I had to fire a Self-Taping Screw thru the top Plate of the body mount down into the steel mount. I then slowly used a 2' Breaker bar to get them out, stripped one so I replaced the Upper Bushing and Bolt (not cheap)
https://dodgeforum.com/forum/3rd-gen...h-guard-3.html
Scroll down some on the page, Youll see what I had to do to get mine off.
Trending Topics
If you can salvage that part with the built-in-nut and drill out the hole to 1/2", grade 8 bolts with nuts and washers are a lot cheaper than buying that whole bushing section from the dealer. If you aren't adding a body lift, get the bolts about 2" longer than the originals, this gives you the length to have the bolt protrude through the upper bushing/washer and to add the nuts - if you don't use a lock-nut, use some "blue" lock-tight or a jamb nut.
