Clunking/knocking noises in front end. Cant find it.
Hello, ive been fixing all the little things on my truck, and im now trying to find the knocking/clunking noise that happens alot more on bumpy surfaces. I just replaced inner and outter tie rods on both sides recently. I replaced the sway bar end links a couple years ago (maybe 10,000miles on em) with moog replacements. It has happened for awhile, and Ive parked the truck for a year and just figuring out stuff. Today, i just replaced the horrible sway bar bushings with energy suspension bushings and I am very sure that it made the noise happen a little more and louder, BUT, it has less sway around corners when i took it around the block. Idk what it is. I checked all the ball joints with a pry bar and they are fine. No excessive movement. Im leaning towards struts. Not sure how to test them however. Sometimes when i took it on speedbumps in the past, it would be a little too lose, which is making me think its struts. I also took it on these rally offroad trails before and it made a clunking type noise when i bottomed out, also making me think its the struts. What do you guys think? 145k miles on it.
I already tested all the ball joints. I first checked it out by jacking it up and trying to move the wheel in the 12 and 6 o'clock postion, and theres no movement. I then jacked it up, and with a pry bar, I couldnt find any movement. I jacked it up by the control arm and couldnt find find any movement. Then jacked it up via the front member and i couldnt see any either.
Calm down there a bit. There was a missing period in his post. He mentioned that on a Chevy that he once had, a clunking noise on bumps was a brake calliper causing it. His experience could be great here.
In your case, It could be one of many things, from the brakes, to the CV's, to the struts, to the control arms themselves or even the steering rack. I didn't mention the balljoints, tie rod ends or sway bar end-links as you say you already checked those which is a good start. Unfortunately, there is no way to really check most of them short of replacing and seeing if the problem goes away. Others might chime in with their experience with noises on their Daks, or it might be on other vehicles, and it might help you trace your noise.
The bushing in the lower strut mount seemed a little squished. I dont think that would cause a clunk tho. Right? Cuz there isnt a gap around the bushing. I had such a big gap with my sway bar bushings, i could see right thru them. So for all that i know, if my lower strut bushing it squished, the others may be too. But i dont know. I put the truck on jack stands and I jacked up each control arm (while looking at the mounts on the frame) at different spots and I didnt see any pause between jacking it the arm and it actually jacking up the truck (so im not suspecting bushing play. They would start squeeking before a total collase i think). I also used a long pry bar and didnt notice any play. Ill look again tomorrow to double check. I do have high miles if its the original struts. 145k. Im gonna inspect the end links tomorrow, and might even remove them and see if the noise diaappears.
Trending Topics
This is on top of the strut. It's an isolator, or strut mount. Not the bushing. Looks like this >> http://shop.advanceautoparts.com/web...ntent=20740155
Well, I just had an assistant rock my truck back and forth while I went under. I noticed two things, my rear sway bar links are making noise. Second, I see both front sway bar end links moving up and down within the mount. They are moog that I purchased maybe 2 years ago. THEY should have no in and out play, right?
