What service does my truck actually need? (2007)
2007 Dodge Dakota 4.7 V8 SLT with 44K miles. Purchased it 3 years ago with 32K miles so it gets appx 4K miles/year, commute driving, no heavy lifting.
Haven’t done much routine service on it since I got it; aside from yearly oil changes, new shocks in the back, new air filter two years ago and put a couple used tires on after getting a couple flats. When looking at my maintenance schedule in the truck’s manual, it looks like most stuff is up to date.
Its last full service was a ‘30K mile service’ from a dealership just before I bought it. Here is a photo of what the dealership did (not sure what some of the stuff is so I figured a photo is more accurate than trying to list it).
https://i.imgur.com/NGog8e2.jpg
I haven’t had the tires rotated but they’re currently different brands with different treads since I replaced the flats with used tires.
Last week I had an oil change done at the dealership and they recommended several services. Wanted to know if they were legitimate services or just the dealership trying to get more $$. They recommended:
-Drain automatic transmission and replace filter/fluid
-Spark Plugs R&R
-BG fuel system induction service ($167)
-Fuel injector service ($165)
-Power steering system flush ($200)
-Flush and replenish brake fluid ($180)
-Perform complete 4x4 drive line service
Not sure why some have prices and some don’t but either way I imagine I would take it to a shop to get a better deal if I needed any of those services.
On a semi-related note, the truck sometimes downshifts kind of hard when braking, usually around 25mph. Doesn’t happen all the time but has existed for a couple years now, some days it’s more frequent than others.
Thanks
-Spark Plugs R&R
Thanks
Trans fluid/filters every 60k miles.
Spark plugs every 30k miles
Air filter as needed
Oil filter and oil depending on your driving habits and oil type (I used synthetic wioth 6000 miles/6 month change interval)
The dealer will ALWAYS try and sell you unnecessary services under the guise of "it's recommended". If you have an owners manual, go by that and that alone. If you dont have an owners manual and consistantly take your vehicle to the dealer for minor services like oil changes, be prepared to be inundated with "recommendations". Dont fall for them.
Run you a can of lucas fuel injector cleaner through every month or so, "periodioc fuel injector cleaning services" are a waste of money.
Half of that crap on that service report is plain old garbage and a complete waste of money. $30 for "battery service"? If you can keep the terminals clean from corrosion, you're doing a bettery service. Combustion chamber cleaner? if your that concerned, run a can of seafoam through it. Wow, sorry, but seeing how people get ripped off by dealers just p1sses me off.....Read your owners manual!
I believe it says "vapor flush o2 sensors and catalytic converter", wth is that? My take is they "power flush" the injectors and throttle plates (even though there is only one throttle plate), then whatever they use to "flush" these parts gets turned to vapor in the combustion chamber, thus "vapor flushing" the exhaust system.....I guess the dealership was just doing that stuff to make it look good for a potential buyer, but honestly, at 30k, the only thing they should have done was change the plugs, oill and filter change. The rest of that is totally unnecessary at 30k miles.
I just bought some Techron, is that similar to the Lucas product or would using both not be a bad idea? (Not at the same time obviously)
Should I get the tires rotated or does it not really matter much since I'm running a combo of various used tires?
Thanks again
Thanks, appreciate the info. So since it looks like the spark plugs were done at 30K, I should be pretty good until 60K with the exception of oil/filter changes.
Thanks again
Thanks again
Whatever fuel injector cleaner you use, just use it like every other tankful if you are having any idle issues or anything like that. Read the labels for the directions.
Trending Topics
check the monther trucking transfer case fluid and if dirty or low replace the fluid. mine has got 160km on the transfer case fluid and boy is she dirty. i got the truck 4500km ago and did not even think to check it till last this weekend and wow its is black and 1 litre low. this weekend i plan on changing it and then in another two months changing it again. atf 15$ worth of fluid, new transfer case 2 grand or more.
