Custom suspension (mid/long travel) happening.
Ok, truck is down, most parts are here or on the way. 3+ inch longer control arms, 12" COs. If I spring for the high angle kore inners (800$), travel maxes out at +14" metal to metal. Trying to stay 0 lift. Planning for 35s. I will now take questions.
Yes. Progress to this point: one side of truck torn down, test of stock travel, test of mock up travel, test of ram axel, parts/materials determined, one uca fabricated, ton of money spent, unusable truck.
Trending Topics
Can we get some details on where the parts came from? And 35" tires on 0 lift sounds really ambitious even with fiberglass but the travel length alone is amazing. What size coil overs are you using and are you going to move the strut mount up? I'm assuming you are doing more than just extending the tie rods so are you doing a heim mod or anything? Also, will you have to drill out the steering knuckles or did you find someone that was willing to find and use correctly tapered studs? You said 14", but how much of that is up travel and how much is down?
I find imgur.com a lot easier to use than photobucket now. Much simpler interface and inserting the image on here seems easier for some reason. PLEASE JUST POST SOME PICTURES.
Yes big travel, 35s, and no lift is not going to happen without serious chop. For now, I am leaving the 32s and stock, cut fenders. The ram 1500 axels will limit the travel to around 10" as well. I will have to add the kore inner cvs later. The 12" COs will be a waste until then.
The parts are coming from ballistic fab, ride tech, and emf for joints, hardware and tubing. I can give more detail about particulars. Foa coil-overs.
Tacked together LCA just now. Tried to mimic stock geometry, just 3 1/8" longer and fully adjustable. Stock tie rods will be lengthened for now. Sorry about the phone posts.
