[Radio] I Just Can't Win!
Old 07-19-2014, 04:18 PM
Gtt1229's Avatar
Gtt1229
Gtt1229 is offline
Default [Radio] I Just Can't Win!
I tried to install an after market radio earlier this year, and it worked fine with a Scosche? accessory that helped supply CAN power, but it eventually killed my battery, so I uninstalled it. I tried again a few months after, this time direct set-up, and I 'decided' to hit the radio with a 12V current and fried it. I just recently bought another radio, started hooking it up today, and of course the wiring harness was wrong. I have no idea what to do anymore.... I'm feeling hopeless. Any help?
Dodge Dakota 2005 w/ Infinity System.
Old 07-19-2014, 10:23 PM
Reject's Avatar
Reject
Reject is offline
I had a aftermarket radio, I used the 12v Outlet under the dash, and had it set to IGN Power so the radio turned off with the truck. No issues or anything wired that way.
Old 07-20-2014, 04:31 PM
Lovinmydodge's Avatar
Lovinmydodge
Lovinmydodge is offline
as mentioned by Reject, the best way without spending a bunch of money on the wiring harness... is to tap into the 12v plug on bottom side of the dash, thats what I've done with all my setups, i had one of the nice wiring harnesses hooked up when I had my comp system in and it fried the dash. killed all power in the dash and everything. needless to say that after than, and the 5+ hrs it took rewiring the entire dash...... i'll never go back to factory integration.
Old 07-20-2014, 07:41 PM
Jaded's Avatar
Jaded
Jaded is offline
Damn, I've heard newer vehicles were a PIA when it comes to the stereo being integrated. Didn't realize it was like this. Guess the days of buying a $20 adapter and poping something in the dash are over.
Old 07-21-2014, 06:55 PM
Gtt1229's Avatar
Gtt1229
Gtt1229 is offline
My 12V power outlet is always hot, I don't know how to change it to accessory, any advice?
Old 07-21-2014, 06:57 PM
Gtt1229's Avatar
Gtt1229
Gtt1229 is offline
Now I'm confused, are we talking about the lighter outlet, or the code scanner system bellow the brake release and hood release?
Old 07-21-2014, 07:01 PM
dakotaff's Avatar
dakotaff
dakotaff is offline
The lighter/12 v power outlet. I can't see tapping into the OBDII wiring doing anything positive.
Old 07-21-2014, 08:20 PM
Gtt1229's Avatar
Gtt1229
Gtt1229 is offline
My 12v is always running hot, I don't know how to change it to ACC
Old 07-21-2014, 08:27 PM
dakotaff's Avatar
dakotaff
dakotaff is offline
You need to change the position of fuse # 22. It controls the power outlet to either always hot, or on with the key.
Old 07-22-2014, 06:16 AM
Gtt1229's Avatar
Gtt1229
Gtt1229 is offline
Oh my god. I can't believe this. I am about to cry from happiness. Thank you so much. I just thought I sucked. You always come through! Thank you again.
File Type: jpg
Quick Reply: [Radio] I Just Can't Win!
