Fix my 42rle
Old 06-29-2015, 08:05 PM
garryburrell's Avatar
garryburrell
garryburrell is offline
Default Fix my 42rle
What is the most common problem with this trans in a 2 wheel drive dakota
Old 07-08-2015, 06:03 AM
04DakAz's Avatar
04DakAz
04DakAz is offline
From what ive gathered, they are cursed from the start.
http://etereman.com/blog/fiat-transm...e-transmission
Overheating, Clutch pack fails, abuse.
I talked to guy once that had a 05 QC 2wd V6, had around 210K miles, said he replaced the transmission 3 times.
Hoping mine goes at least 180K, only time will tell. Just change your fluid often and filter and hope that Chrysler engineering shines thru
Old 07-11-2015, 01:25 PM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
Dodge Forum Moderator
I'll move this to the 3rd Gen forum.
Old 07-11-2015, 10:10 PM
Jaded's Avatar
Jaded
Jaded is offline
Maybe if you let us know what problem you're having someone can help.
Old 07-24-2015, 09:12 PM
garryburrell
My temp light came on and it was slipping in first. It also was shifting funny.
Old 07-24-2015, 10:26 PM
italiandominator's Avatar
italiandominator
italiandominator is offline
Got 168K miles racked up so far...
No real issues with the tranny at all (knock on wood)
Granted, I kinda babied her for the first 75K; plus, I flushed the fluid twice thus far (so vary happy I installed a drain plug after the first flush)
Old 07-25-2015, 12:26 PM
superdak05's Avatar
superdak05
superdak05 is offline
do a through fluid change and filters,
Old 07-26-2015, 03:50 PM
garryburrell
I also could be driving and have to speed up fast so I floor the pedal and it will rev the motor up to 5 and 6 k then the truck will slowly speed up
Old 07-26-2015, 05:09 PM
dakotaff's Avatar
dakotaff
dakotaff is offline
Hopefully a mod will merge this thread with your other similar thread, try to keep it all in one place.
Now, when was your trans fluid changed last? Were the filters changed too? These trucks will shift better with OEM trans filters.
Old 07-27-2015, 08:59 PM
garryburrell
I wanted one in the Dakota forum and one in the ram forum so I would get more ideas but I guess a mod didn't won't it that way.
Quick Reply: Fix my 42rle
