Steering problem
Steering problem
Hello I recently brought a 2006 Dakota st with 53xxx miles. I noticed that when I turn to the left the steering is super loose. I can turn the wheel with just one finger. In comparison to when I turn to the right it is a lot tighter. I recently got 4 brand new tires and changed the upper and lower ball joints on the right side. The reason being is that when I went to go get an alignment the mechanic showed me that they needed replaced. So I was like maybe that will fix the loose steering when turning left. It didn't. So before I get an alignment I want to make sure that I fix this problem first.
Thanks for the help,
Jared
Jared
That's actually the INNER tie rod you have a picture of; the ball jointed end is inside that bellows.
However, the bellows shows that the rack is leaking; most replacement racks can be had with new inner tie rods, so you may want to consider that first instead.
There are several sources; I'd recommend considering The Rack Doctor ( www.rackdoctor.net )
RwP
RwP
RwP
RwP
