No crank 2011 ram dakota.
Old 03-13-2017, 12:25 PM
granite779's Avatar
granite779
granite779 is offline
Default No crank 2011 ram dakota.
Dash lights work but no crank when trying to start. Starter solenoid relay replaced,and new battery installed, still no power to trigger wire at starter. Jumping solenoid makes engine crank but will not start. Any ideas?
Old 03-13-2017, 12:27 PM
granite779's Avatar
granite779
Getting fuel but no spark when cranking engine by jumping solenoid. Is there a way to bypass park safety switch?
Old 03-13-2017, 12:46 PM
jkeaton is offline
Dodge Forum Administrator
Moved to the correct section.
Old 03-14-2017, 09:12 AM
rodslinger's Avatar
rodslinger
rodslinger is offline
Checked all fuses? Security issue? Any codes? If you put shifter in neutral will it turn over then?
Am thinking that park safety switch would just block starter engagement but not ignition.
Old 03-14-2017, 02:43 PM
granite779's Avatar
granite779
It will not turn over in park or neutral. Only code is low voltage. Changed starter switch, put a new battery in, triple checked all fuses and relays.
I am thinking maybe it is a bad PCM ? since it will crank but wont fire when I jump the starter solenoid.
Old 03-14-2017, 06:44 PM
rodslinger's Avatar
rodslinger
Does your done light work when you open the door? By chance does your keyfob still lock and unlock the doors?
I had the same thing happen once on my 2011 after changing the battery. I noticed the remote would not unlock the door and the dome light didn't come on with the door open. Everything else worked but the truck would not start.
Ended up just disconnecting the negative terminal again for a few minutes and the issue cleared. Have heard that this may be caused by the wireless control module. It isn't recognizimg the security on your key and preventing startup. Tried your 2nd key?
Old 03-14-2017, 07:17 PM
granite779's Avatar
granite779
Yes the dome light does work. It is a base model and has no power doors or windows so no keyfob. I bought the truck used last year and I only got one key. We tried removing neg wire from battery a couple times but it did nothing different. I also wonder about the wireless module but dont know how or if it can be tested?
Old 03-14-2017, 07:55 PM
erau's Avatar
erau
erau is offline
There's no flashing security light on the dash to indicate it doesn't recognize the RFID chip in the key after swapping batteries?
Old 03-14-2017, 09:15 PM
granite779's Avatar
granite779
No sir, no flashing security light on dash.
Old 03-15-2017, 08:46 AM
wingman7000's Avatar
wingman7000
wingman7000 is offline
It sounds like it is in auto shutdown mode. I had the same issue with mine. I added a factory keyless entry from a wrecked truck and an aftermarket remote starter.
My opinion is to rent (its free) a scanner, available from your local AZ and see what, if any, codes are coming up. Get the best one available. Mine had a P0633 no secret skim code and P0513 invalid key. Don't take it to your stealership. I made that mistake and they will only try to sell you a new PCM at around $1600. I told them no. I sent the PCM to a car computer place and they erased the error code for around $125-$150. I got it back within a week and plugged it in and it started immediately. I had no security light on the dash either since mine is a base model too.
Quick Reply: No crank 2011 ram dakota.
