Door Lock Wiring Diagram
Old 03-14-2017, 10:54 AM
redbirdfaninkc's Avatar
redbirdfaninkc
redbirdfaninkc is offline
Default Door Lock Wiring Diagram
I purchased a power tailgate lock for my 2011 Dakota. The instructions do not tell what wires I need to tap in to. I know that I need to tap in to the door lock and unlock wiring. I have looked on the internet and had no luck finding a clear answer.
Any ideas on where I can find this?
Old 03-14-2017, 11:18 AM
jkeaton is offline
Dodge Forum Administrator
You want the tailgate to lock and unlock every time you lock and unlock your doors?
Old 03-14-2017, 11:28 AM
redbirdfaninkc
That is correct, by using the remote and/or the door lock in the truck.
Old 03-14-2017, 03:44 PM
redbirdfaninkc
Default Corey
I am trying to install a power tailgate lock on my 2011 Dakota. It has to be wired in to the door lock/unlock wiring. The instructions it came with are vague and do not specify what color the wires are. I have looked on the internet and had no luck finding a clear answer. Any ideas?
Old 03-14-2017, 03:47 PM
jkeaton is offline
Merged your duplicate threads. Only one is needed. Thanks.
Old 03-14-2017, 05:45 PM
dakotaff's Avatar
dakotaff
dakotaff is offline
Not sure if the colors have changed, (probably so), but here is the 05 Dakota door lock.
Old 03-15-2017, 08:14 PM
Pspklutch's Avatar
Pspklutch
Pspklutch is offline
Something to keep in mind, sometimes these aftermarket lock solenoids take a lot more power than the factory lock circuit can handle through the lock switch. If you don't have enough power (it may make your normal locks sluggish or not work at all) you will have to wire up two 5 pin relays to deliver more power to the aftermarket actuator.
