3rd Gen Durango 2011+ models
Do It Yourself (top question and answers) and FAQs
Old 06-22-2011, 11:40 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
Default Do It Yourself (top question and answers) and FAQs
This thread will be continuously updated.
Check back often!
We are not responsible for any mishaps while you are wrenching, knuckle busting, throwing tools, kicking vehicles, stomping, whining, drinking, or possession of you or your rig by any entity....... Always consult a manual before attempting any wrenching and I advise you to stay within your skill set. If you’re expanding your skills, work on the easy stuff 1st to gain skills and the necessary scars on the hands to fall into the "working man/woman" category.
With that said lets open the door.
Keep in Mind that this will serve as a reference for you and everyone else who need information about these trucks, if you see something that you feel should be in this thread that I have missed please PM me so that it makes it in. Also this will grow as you the members make modifications to your rides and share your experiences and the knowledge you have gained in the process.
MyGig Lock Pick V4 Install
https://dodgeforum.com/forum/3rd-gen...ml#post2533572
Media Center 430(RBZ) update ISO
http://www.mediafire.com/?ve1wplfq27usajq
Uconnect software
https://dodgeforum.com/forum/3rd-gen...ter-430-a.html
update file for usb memory keys
http://www.mediafire.com/?v2c6nhulwx7438a
Fuzzy Backup Camera Image
https://dodgeforum.com/forum/3rd-gen...p-cam-fix.html
Headlight bulb replacement
without removing bumper
https://dodgeforum.com/forum/3rd-gen...d-install.html
removing bumper
https://dodgeforum.com/forum/3rd-gen...t-removal.html
DIY Daytime Running Lights (DRL)
https://dodgeforum.com/forum/3rd-gen...4-drl-dyi.html
Home Made Front Tow Hooks
https://dodgeforum.com/forum/3rd-gen...tow-hooks.html
Old 01-11-2012, 11:30 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
Engine Oil Change Indicator System — If Equipped
Oil Change Required
Your vehicle is equipped with an engine oil change indicator system. The “Oil Change Required” message will flash in the EVIC display for approximately five seconds after a single chime has sounded, to indicate the next scheduled oil change interval. The engine oil change indicator system is duty-cycle based, which means the engine oil change interval may fluctuate dependent upon your personal driving style.
Unless reset, this message will continue to display each time you turn the ignition switch to the ON/RUN position. To turn off the message temporarily, press and release the Trip Odometer button on the instrument cluster. To reset the oil change indicator system (after performing the scheduled maintenance) refer to the following procedure.
Turn the ignition switch to the ON position. Do not start the engine.
Fully depress the accelerator pedal, slowly, three times within 10 seconds.
Turn the ignition switch to the OFF/LOCK position.
Note: If the indicator message illuminates when you start the vehicle, the oil change indicator system did not reset. If necessary repeat this procedure.
Quick Reply: Do It Yourself (top question and answers) and FAQs
