Road Magnet springs installed
#22
I have 275/40/22 Nittos wrapped around Factory Reproductions Vipers. If you think the rubbing is from the outside edge of the tire hitting the plastic trim that goes around the fender lip, then I *might* be OK.
I wish they were a little stiffer rate than stock though. Hmmmm, I thought this was something that was mentioned by Black Ops (slightly stiffer, less body roll).
#23
once aware of it, I have been able to avoid rub pretty much altogether by slowing down more on the worst and well known road dips..
Only once or twice in last 5 days (once doing 75+mph and once on a surprise
dramatic dip) have I had noticeable rub
if you typically drive the speed limit, frequent the same roads often, and/or live in a newly paved or well preserved city you should be fine. Otherwise, may need to do a gut check before going forward...
#25
#28
