2014 drl - DodgeForum.com
3rd Gen Durango 2011 models
2014 drl
Old 07-13-2014, 04:53 PM
JRRF
JRRF is offline
Default 2014 drl
So I'm trying to figure out how the daytime running lights work without an extra pair of eyes. These are the two things I found in the manual:
The Daytime Running Lights come on whenever the engine is running, and the transmission is not in the PARK position. The lights will remain on until the ignition is switched to the OFF or ACC position or the parking brake is engaged. The headlight switch must be used for normal nighttime driving.
When this feature is selected, the headlights will turn on whenever the engine is running. To make your selection, touch the “Daytime Running Lights” soft-key, until a check-mark appears next to setting, indicating that the setting has been selected. Touch the back arrow soft-key to return to the previous menu
Of course these things contradict each other. Either you need the car in drive or not. And one implies there are separate DRLs, the other talks about the headlights. So how does this really work? I keep my headlight switch in "auto", but so far I've not seen the headlights or LEDs come on unless I turn on the headlights or parking lights. Of course I have to have my car in Park to do this...
Thanks.
Related Topics
Thread
Forum
Replies
Last Post
Vader2014
11
10-28-2015 02:29 AM
MoparMan1991
4th Gen Ram Tech
3
09-27-2015 11:14 PM
chris_smith-1986
4th Gen Ram Tech
2
09-23-2015 10:52 PM
trace001
Dodge Charger
0
09-23-2015 06:12 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
