I have a 2011 Crew. I just realized that when I use the key fob to unlock it, the headlights flash but the rear lights do nothing. Can an owner confirm this is the same behavior with your rig or do your tail lights flash as well?
Thanks
jtorral,
The Remote Keyless Entry settings can be adjusted through the EVIC system in your Durango.
When selected, the "Flash Lamps with Remote Key Lock" will cause the turn signal lamps to flash. There is also a "Turn Headlights on with Remote Key Unlock" which will activate the headlamps for 90 seconds.
Have you recently adjusted any settings in your EVIC?
