5.7 T-Stat
Not aware of the duralast stat being an option. Is autozone claiming its a direct replacement? The two I'm aware of is the Murray 4128 which needs to be modified( grinding the circumference a few mm and the Jet 180 stat. I believe Steve knows we're to get one cheaper than jet or summits website. I use the modified Murray unit.
Thanks for the help, guys. I am getting tired of seeing 215-220 degrees while in slow traffic or idling. The heat soaking seems to sap some performance as well. Want to accomplish this before moving on to a Diablo In tune programmer.
I am assuming it would be this thermostat, correct?
http://www.highhorseperformance.com/...10183-usps.htm
Trending Topics
The claims of " fail safe" thermostat are very amusing to me since it is impossible for any company to predict that either spring will break. All thermostats by design simply lock themselves open if but only if it's already in the full stroke open position. It will not spring open if it fails in a closed position.
