I need advice on differential and transmission fluids change
Thank you your reply. The owner's manual doesn't say specify after what mileage a change shall be carried out.
Here is a link to the owners manual. In the "maintaining your vehicle" section, it specifies fluids to use and in the "maintenance schedules" section it lists the mileages you should be performing scheduled maintenance.
http://m.dodge.com/download/pdf/manu...ad-button.y=12
The mileage for recommended change are :32k, 64k, ...and so on. I have changed it before. Does this mean it might be damaged?
Thank you for sharing the owners manual. I must've overlooked the schedule maintenance recommendations. However, I'll appreciate if you could help me in explaining this quote from the manual "Inspect the front and rear axle fluid, change if using your vehicle for police, taxi, fleet, off- road or frequent trailer towing.
That's what they mean by "SEVERE SERVICE". There should be a column for normal and severe in the schedule. The intervals will be shorter.
Trending Topics
When I took my 2013 DD Hemi for the oil change I also asked to do the Transfer Case and Differential fluids check (as stated in manual). Service writer told me that there is nothing to check - systems are sealed. Based on my normal driving and averaging about 6K miles/year, looks like I'll wait the 12 years stated in the manual to perform the fluids and transmission filter changes.
