3rd Gen Durango 2011+ models
Starts after 3rd try...
Old 03-03-2017, 10:37 PM
hellomoto_25's Avatar
hellomoto_25
hellomoto_25 is offline
Oh, and we can't be the only ones having problems.
Dodgecares, can you weigh in on this?
Old 03-06-2017, 09:55 AM
jsawhite's Avatar
jsawhite
jsawhite is offline
oh and just for reference, here's the thread I started when I had the issue last time...
https://dodgeforum.com/forum/3rd-gen...-not-tipm.html
Old 03-06-2017, 10:30 AM
DodgeCares's Avatar
DodgeCares
DodgeCares is offline
Has anyone had a diagnosis or gotten any specific input from their dealership about this particular instance? I don't have any experience with this particular concern.
Kori
Dodge Social Care Specialist
Old 03-06-2017, 11:00 AM
TNtech's Avatar
TNtech
TNtech is offline
Site Moderator-Dodge Tech
Dodge Forum Moderator
The same marks the circuit board relays were making on the contacts. Figures.
I've had the ASD relay fail on the TIPMs after the recall and it warrants a TIPM replacement. No sanctioned kit for the ASD failure as of yet.
Good news is..TIPMs are going away. Bad news.....more computers.
Old 03-06-2017, 07:53 PM
hellomoto_25
My wife couldn't get the vehicle started last night or this morning. I sat in the phone with her as she attempted 8 straight times.
Called dealership and they said to have it towed. She tried one last time as I was calling for the tow and it started. She drive it over to the dealership and of course, they couldn't replicate the problem. She's in a rental until tomorrow and if they can't duplicate then we get it back and roll the dice until it stands her somewhere. Not happy about this. They want to charge my $100 deductible on my Max care MVP plan. That shouldn't happen. This is related to the recall fix.
Old 03-07-2017, 08:26 PM
hellomoto_25
Supposedly it's the fuel pump assembly. At least they were able to see the issue this morning when they tried to start it.
Old 03-09-2017, 07:52 AM
SHO Rod's Avatar
SHO Rod
SHO Rod is offline
I'm interested to hear if a new fuel pump assembly fixes this issue. My 2011 Hemi doesn't like to start after sitting several hours (overnight, after several hours at work, etc.). It will crank for several seconds upon the first Start button press, but if I let it crank about 3 seconds, press the button again, then press the button for a second start attempt, it usually fires right up.
Last night I put a fuel pressure tester in series with the fuel line and found that it doesn't build fuel pressure until the engine is cranking, but once the engine is running, it's right at 60 psi (spec is 58 +/- 2 psi). Then once the engine is shut off, the pressure bleeds off within a matter of a few minutes. I expected that either opening the door and/or pressing the Start button for the Run mode would engage the fuel pump, but that doesn't seem to be the case. Oh, I also had a test light on the output from the TIPM to the fuel pump and that light confirms that even when the starter is cranking the TIPM is sending voltage to the fuel pump (haven't confirmed it's getting to the pump though I suspect it is).
Does anyone know if it is normal for the fuel pump to not engage until the starter is running? Also, does anyone know if there is a check valve in the fuel pump assembly or elsewhere that should maintain fuel pressure? Of course I didn't test the fuel pressure until I had a concern, so I don't know what "normal" behavior is. I'm also trying to figure out a way to test each section of fuel line to determine if the pressure is bleeding off back to the fuel pump or to the fuel rail. There is no fuel odor normally so I'm pretty confident I don't have a fuel leak.
-Rod
Old 03-09-2017, 08:37 AM
coldsteel's Avatar
coldsteel
coldsteel is offline
If you switch your ignition to RUN (without starting) you should always hear the fuel pump relay click on and the fuel pump whine before you ever attempt to start it.
The pressure also should not be bleeding off (or back into the tank) when you shut down. The fuel rail should hold pressure.
Old 03-09-2017, 09:47 AM
TNtech's Avatar
TNtech
TNtech is offline
That shouldn't happen, at least not all the way. Maybe 10 or 15 psi but that's it. The check valve is part of the pump assembly.
The relay will pull in for 3 seconds then release when the ignition is turned ON, then close again when cranking begins.
Old 03-09-2017, 01:05 PM
SHO Rod's Avatar
SHO Rod
SHO Rod is offline
Thanks for the info. Looks like I need to dig in to why my fuel pump relay does not activate until the starter is engaged as well as think about changing the fuel pump to address a check valve that appears to be stuck.
-Rod
