3rd Gen Durango 2011+ models
Kimberley
Old 03-17-2017, 07:31 PM
kimmarcil's Avatar
kimmarcil
kimmarcil is offline
Default Kimberley
My liftgate on my 2016 Dodge Grand Caravan won't open with the Fob or the interior lock buttons?
Old 03-18-2017, 11:32 AM
SHO Rod's Avatar
SHO Rod
SHO Rod is offline
While this isn't the proper forum for Grand Caravan questions, I'll respond anyway.
Do you get an indication that the vehicle acknowledges the request to open the liftgate? If so, have you tried to manually assist it in opening, or opening the liftgate manually? If it will open with your help, or manually, but will not stay open, the issue is likely that the gas strut/struts that assists with opening and keeping the liftgate open is/are likely worn and need to be replaced. Replacing them should get the automatic feature working again.
-Rod
Old 03-18-2017, 12:05 PM
DDCREW's Avatar
DDCREW
DDCREW is offline
For a 2016 it should still be covered by factory warranty. Why not take it to the dealer and have him fix it?
